yokobellcandy
Quotation On A 5 Room Flat.
Just bought a 5 rooms flat and need some advice on renovation. Is the prize in the quotation reasonable and if there anything that are not necessary to be done as for now?
A KITCHEN ( tiles range from $ 2.5 to $ 3 per sqft )
1 to hack away existing wall tiles , floor tiles , cabinet etc and clear debris off site 1000.00
2 supply and lay ceramic wall ties up to ceiling height 2150.00
3 supply and lay ceramic floor tile with HDB required prepack cement and water proofing
membrane to floor trap area 1200.00
4 to construct a 50mm height kitchen cabinet base and a washing machine base 250.00
5 to fabricate top and bottom kitchen cabinet ( L shape ) with Laminated finishing and
ABS trimming ( approx 57 ft ) 5700.00
6 supply and install solid surface work top ( approx 28ft ) 1820.00
7 supply and install a stainless steel refuse chute 120.00
8 supply and install Aluminum casement window ( silver frame ) with light tinted glass 330.00
9 supply and install a 6 hook aluminum bamboo holder 30.00
10 supply and install a top track frame less Temper glass door at kitchen entrance 600.00
11 supply and install a dish drying rack with a lift up glass door with wooden frame F O C
12 supply labour to install sink , cooker hood , stove and oven F O C
B BALCONY ( tiles range from $ 2.5 to $ 3 per sqft )
1 to hack away existing aluminum sliding door and floor tile and clear debris off site 200.00
2 to raise up balcony flooring with extruded polystyrene foam and Brc mesh 200.00
3 supply and lay 60 cm x 60 cm Homogenous floor tile with skirting 540.00
4 supply and install Aluminum casement window ( silver frame ) with light tinted glass 870.00
5 to apply a layer of cement strengthener to form key on existing wall tiles & provide
Skim coat over it F O C
C COMMON TOILET ( tiles range from $ 2.5 to $ 3 per sqft )
1 to hack away existing wall tiles , floor tiles , toilet bowl and basin and clear debris off site 600.00
2 supply and lay ceramic wall ties up to ceiling height 1650.00
3 supply and lay ceramic floor tiles 500.00
4 supply labour , tool and material to provide water proofing membrane 250.00
5 labour charge to install a toilet bowl 90.00
6 labour charge to install a wash hand basin and tap 80.00
7 supply and install a aluminum frame bi -fold door with Acrylic panel 200.00
8 supply labor to install a storage tank heater 100.00
9 supply labour to install a rain shower ( expose piping / exposed rain shower ) F O C
10 supply and install a frame less tempered glass shower screen with handle 580.00
11 to reposition existing toilet entrance 320.00
12 to fabricate a storage cabinet with laminated finishing 300.00
D MASTER BEDROOM TOILET ( tiles range from $ 2.5 to $ 3 per sqft )
4 to fabricate a storage cabinet with laminated finishing 300.00
5 supply labour , tool and material to provide water proofing membrane 250.00
6 labour charge to install a toilet bowl 90.00
7 labour charge to install a wash hand basin and tap 80.00
8 supply and install a aluminum frame bi -fold door with Acrylic panel 200.00
9 supply and install a long bath with a curb to conceal inlet with tiles finishing 1200.00
10supply and install aluminium frame ( acrylic panel ) sliding shower screen above long bath 580.00
E LIVING ROOM / DINING ROOM ( tiles range from $ 2.5 to $ 3 per sqft )
1 to hack away existing floor finishes and skirting and clear debris off site 1,100.00
2 supply and lay 60 cm x 60 cm Homogenous tiles with skirting 3,600.00
3 supply and install L box 650.00
4 supply and install aluminium casement window for dinnig room 440.00
F BEDROOMS
1 supply labour and tool to varnish existing parquet flooring 750.00
2 to dismantle 3 wardrobes and clear debris off site 300.00
3 to fabricate a full height wardrobe with casement door with laminated finishing and
ABS trimming at main bedroom ( approx 7.5 ft ) 1,680.00
4 to fabricate a full height wardrobe with casement door with laminated finishing and
ABS trimming at bedroom 2 ( approx 6.5 ft ) 1,450.00
5 to fabricate a full height wardrobe with casement door with laminated finishing and
ABS trimming at bedroom 3 ( approx 6.5 ft ) 1,450.00
to seal up ventilation louver above door frame of 3 bedrooms and store room 80.00
4 supply and install aluminium casement window ( silver frame ) with light tinted glass at
3 bedrooms 980.00
G SKIM COAT
1 supply labour , tool and material to provide skim coat to whole house wall and ceiling
except tiling area 2,500.00
H PAINTING WORK
1 supply labour , tool and material to paint oil sealer to skim coat area
2 supply labour and material to paint whole house wall and ceiling including piping 1700.00
, door and door frame ( I C I Pentalite )
I PLUMBING WORK
1 supply and install stainless steel water supply pipe for kitchen and connect inlet and
outlet for kitchen sink and washing machine 700.00
2 to provide hot water point for long bath at master room toilet and shower point at
common toilet 140.00
J ELECTRICAL WORK
1 supply labour , tool and material to provide rewiring work to whole house existing point
including new switch and socket cover and a new Db box 1,800.00
2 labour charge to install all lightings
if additional point required , charges are as followed :
a to provide 13amp single socket $ 40 each
b to provide 13amp double socket $ 55 each
c to provide scv point $ 100 each
d to provide tel point $ 50 each
e to provide lighting point $ 35 each
f labour charge to install light $ 9 each
g to provide 15amp aircon point $ 65 each
h to provide heater point $ 65 each
i to provide door bell point $ 35 each
K OTHERS
1 to remove all cornices F O C
2 HDB permit fee F O C
3 cleaning up upon completion F O C
4 to fabricate shelvng for store room ( 3 tier ) 240.00
TOTAL $44,690
quite cheap. but be careful of hidden cost in the end.
I pointed some weirdness tho' :
Plumbing works doesn't make sense. They hack away the whole toilet floor and wall but then they never include piping replacement cost. Are u expecting to use back the old pipes which most probably will be damaged by the hacking works?
