Troublemaker
Bachelorette On Budget
I went to my new house and found that there are black and white stains on the homogenous tiles. The homogenous tiles are those reflective type.
Does anyone know how to remove those stains on the tiles? Its not the dirt on the grout.
This is how I remove stains from my white marble. Not sure if it works on homogeneous tiles so I suggest you try out on an obscure piece first.
http://www.renotalk.com/forum/topic/62505-top-kew-drive/?p=842435
For stubborn stains, you may have to do it several times.
Note: Do at your own risk! I disclaim all responsibility!
Edited by kstoh
Thanks so much!
What could be possibly worse? Just change the flooring loh... ahahahha... But, that will be my last alternative...
Sorry to hijack the thread....while we are on topic of stains~ anyone knows how to get rid of green colored oxidization on aluminium windows? :P
This is the final result!
On a "closer" look:
">http://gallery_59611_304_5610.jpg
On a "farther" look
">http://>gallery_59611_304_2821.jpg
And the winner is: Daiso Sponge!!!
As the Daiso sponge is made of melamine, do remember to wear a pair of rubber gloves when using it.
As for the stain remover cleaner, I realised that it can clean the gaps between tiles very well. I don't need to exert any strength in cleaning the grout at all!
  • Like 1
This is the black stain on my tiles
">http://gallery_59611_304_6513.jpg
Actually leave all this to your contractor mah, you can save the trouble.....
really? The contractor will help me clean it meh? foc?
If your quotation got "chemical wash" then maybe your contractor may clean it for you.
On second hand, I am thinking if I should change the tiles to ceramic tiles coz I doubt that the stains will be all gone. And those homogenous tiles seems to be easily stained with water... Thinking in the long run, the tiles will get darker with time and possibly its a better idea to change all the tiles?
You mean the tiles was not changed? In this case, the stains are left by ex owner? Then you have to clean yourself lo
If you don mind, can consider overlay which will save some cost.
  • advertisement_alt
  • advertisement_alt
  • advertisement_alt
