vorks
Marble Floor Polishing - Reasonable Price?
hi there, trying to polish the marble floor for my living room.
So far my quotes are at $600. Is this reasonable?
If not, does anyone has any lobang to intro?
thanks!
thanks!
It depend how big is your living room....should be around $300-$450, u going to direct or thru contractor/ID?
Not very big leh...I went through contractor too. But is like a main contractor...think too expensive...i search around abit more.
BTW - wet vs. dry polishing which one better ah? I suppose is dry but its more expensive? Is it significant noticeable difference?
hihi, a contractor quoted me $1.2k for polishing of marble flooring of my living room + 3 bedrooms.. is this reasonable? :unsure:
anyone has got better quotes to recommend me?
thanks!! :)
Hi, I just called the contractor that did my house last year. He told me $350.
Best regards.
hi samsontok, so ur quote of $350 covered living room only? how big is ur unit?
i got a quote of $1.2k for living room + 3 bedrooms.. and mine's a 5 rm flat..
What is your sq area for those rooms?
erm, my entire flat is 110sqm.. so minus the 2 toilets + kitchen, got about 90 or 85sqm? reasonable? :unsure:
Ard $1K la..As I said b4...it was here few hundred there few hundred that make up their earning, they won't dare to mark up too high for every items if not when u see the quotation, u also won't want to engage them too.
hi,
can pm me your contact pls? looking for homo tiles polishing too... ...
tks in advance
Best regards.
Best regards.
Hi, appreciate if you could PM your contact. Thanks in advance.
Hi, u can contact Jin's brother. They polished my living rm for $480. Very good services. You can go the website www.jinsbrother.com and contact Irene.
