simpleguy80
Ba Gua Mirror
Is it better to put one "Ba Gua" mirror on top of the door if the unit is facing lift lobby? Where do I buy and initialise the mirror? How much one cost? Is there a particular date and time to put up the mirror or need a master to do it? Thanks.
Mirror is not ornament. Don't need initialization.
There are two type of mirror, concave and convex. Buy a convex type to diffuse the engery. Some believes Ba Gua can block away SHA eg sharp object of a building, T-junction..etc. A lift lobby is consider as movement for stirring up the engery not a sha, but placing a bagua makes you feel comfortable by all mean. Place it ASAP no need to look up particular date/time since this a cure.
Its better that you get a reliable master to check whether its necessary to put up the mirror in the first place.
Don't need any date and time to put it.
