tientien
Ventilation Exhaust Fan Installation For Toilet ?
Got a question on the HDB permit - the contractor says it will be posted to you by HDB, is this correct?
Anyway the fan installation didn't happen today - the contractor from central aluminium / Jasmine's company measured or cut the wrong hole size and today the glass cracked when trying to squeeze in the fan :) Got to call them to see what next....
Edit: Update, they fixed it.
Edited by sepultura
You can check the permit approval online in HDB website.
BTW, the ventilation fan that's approve by HDB is the square one, not the round one (at least in my permit) .... though lots of people seems to install the round one.
i'm also thinking of installing one in one of the bathroom. The air circulation there is awful and everything dries up so so slowly. Thigns can grow mouldy very fast.
Here u go, tel 63683313 Jasmine
I found these are the several model..
http://kdk.jp/product_show_all.aspx?id=12
i fill up the KDK website contact us..
someone from Capital email me back on the Ventilation Fan
Thanks for your support to KDK product. Kindly refer the following for your information.
KDK Window-Mount Ventilation Fan (Recommended for Kitchen)
- Model: 20WHA
- Diameter: 200mm
- Cord-operated shutter
- Noise level: 41.5dB(A)
- Capacity: 440CMH
- Price: $190.46
* Price quoted above is To Supply only and GST inclusive.
* Installation Charge estimated $200-220 with all accessories.
Do feel free to contact us should you be any clarification.
Warmest Regards,
SOLE DISTRIBUTOR:
Capital Distributors (S) Pte Ltd
Edited by steventay
Hi!
Anyone know where should i go to get KDK ventilation fan that is cheaper??
Looking for smth like 15WHA!
Thanks in advance!
Edited by piggyboo
Hi would like to check how do you secure the acrylic panel to the window frame as I have intention to try DIY.
you can screw it onto the tiles, but u need to get a drill thats able to drill thru tiles without cracking the tiles.
Dama.com.sg does customising. I did mine there, acrylic panel costs $46. (a large piece, as i covered up the whole window instead of screwing the panel on the aluminium frame.
hi, im also thinking of fixing a ventilation fan in my toilet. What is the ventilation powered? Is it battery op or requires electricity? If its electricity, Im worried that I have to run an electricity line to my toilet (mine is a post renovation improvement project).
I would like to install 2 exhaust fans for the master and common toilets.
believe i have to rebuild the window and frame and install powerpoint.
Do let me know if you have any good recommend sevices provider.
