ben1977
Difference In Downlights?
Can anyone help to differentiate on Which type is better for downlights?
1) PLC
2) Direct voltage ( aka PLL???)
Thank you!
i think the comparison as follows:
PLC
- needs magnetic ballast to work
- may flicker when switched on
- cheaper
- consume more power
PLL
- require electronic ballast to work
- instant-on when switched on (flicker-free)
- downlights have electronic ballast built-in so will be more exp when replacing, no external components (eg, magnetic ballast) less propability of failure. so when replacing new PLL lights, everything is new.
- consume less power
Edited by neubie
PLC
- cheaper
PLL
Thanks Nuebie! Different sales people tell me different things..i wondering which one to take for my home as my contractor says PLC while the guy in the lighting shop say PLL better....
Off topic....
Did you see any of those light without bulb and ballast?
I'm into LED, but have an issue buying light casing as most shop sell them with ballast.
Hi guys, this PLL you talk abt is not Energy Savings Bulb right?
The energy saving bulb isit call CFL?
Cos i went to jalan besar and one of the shops rec'd me use energy savings bulb, no ballast so when fail, no need to guess is ballast or bulb fail.
Any ideas? Thanks.
Any ideas? Thanks.
wa lau... another new terms *faint*... bro, any picture of the CFL?
Any ideas? Thanks.
Yes CFL is the bulb-type used.
