pixie
100-drop On Floorplan
On my floor plan, there is a few areas that says 100 DROP.
What does this mean?
I think it is for the beam on the ceiling. Does it mean it cant be hacked?
Like toilet floor is lower then outside, to ensure that if kena flood, the water wun flow out to other rooms. does not mean is beam, kitchen is also normally lower than living room.
It means a drop in level of 100mm.
i believe the drop is at the balcony area linking to the living room. It's a just a small drop of 10cm. Advise you to level it to living room, so that the latter will look more spacious. =)
i agree. definitely level it if you can.
