zero
Samsung Side by Side Fridge RS552NRUASL @ $1299
Features:
  • Premium design for the modern kitchen
  • Multi Flow
  • Bring frost-free freshness into your kitchen
  • A brighter way to save energy
  • Twin Cooling System™ gives you the best of both worlds
  • Preserves your food longer, keeps your electric bills lower
Capacity
Gross
  • Total: 590L
  • Freezer: 217L
  • Refrigerator: 373L
Cooling Features
  • Cooling System: Twin Cooling
  • No frost: Yes
  • Multi flow: Yes
Others
  • Door Alarm: Yes
  • Refrigerant: R600a
  • Cyclopentane Insulation: Yes
  • Silver Nano health system: No
Category
  • Refrigerator Type: SBS
Physical Specifications
Dimension
  • Net (WxHxD): 912mm
  • Net Case Height with Hinge: 1,789mm
  • Net Case Height without Hinge: 1,789mm
  • Net Depth with Door Handle: 700mm
Weight
  • Net: 110kg
Special Feature
  • CoolSelect Zone: No
Thank you.
Regards,
Jerome
92256638
homeappliances@hotmail.sg
Samsung 2 Door Black Fridge RT38FAU @ $ 880
FEATURES:
Always working always dependable
The new Samsung refrigerator’s smart and durable technology ensures long-lasting performance.
Digital Inverter Compressor
Unlike conventional compressor which continually start & stop, Samsung’s Digital Inverter Compressor makes slight adjustments based on humidity levels and usage patterns.
This helps maintain a more consistent temperature, reduces wear and tear on the compressor for greater reliability and keeps noise to a minimum. You’ll enjoy a 10-year motor warranty.
Easy Handle
The Easy Handle is a new way to open doors. Simply click on the handle’s button and it pushes the body, enabling easy and effortless opening. Crafted for your comfort and convenience, this innovative handle makes opening the sturdy door of Samsung’s new refrigerator a breeze, without any extra force.
Cool Pack
In the event of a power outage or if the electricity is turned off, Cool Packs inside the freezer keep foods frozen for up to an hour with no power. They also help the freezer compartment stay cold for up to eight hours, so your food won’t melt or spoil.
Moist Fresh Zone
A smartly designed drawer that provides an optimal environment for storing perishable food, so it stays fresher longer.
A tight seal prevents moisture from escaping when humidity levels are low, and a vent releases excess moisture when humidity levels are too high.
Easy Slide
Reaching into a refrigerator often means navigating an obstacle course of food items. But the Easy Slide shelf is built on rolling hinges and pulls out, so you can efficiently organise and easily access your food items – and easily see exactly what you have stored in the back.
Rating: 3 TICKS
Specifications:
Capacity
  • Gross Total(Liter): 385 ℓ
  • Gross for Freezer(Liter): 88 ℓ
  • Gross for Refrigerator(Liter): 297 ℓ
  • Net Width(mm): 675 mm
  • Net Weight(kg): 68 kg
  • Net Case Height with Hinge(mm): 1,785 mm
  • 20/40/40H (Container): 70 (40 H Container)
  • Net Depth without Door Handle(mm): 668 mm
Cooling Feature
  • No Frost: Yes
  • Multi Flow: All around cooling
Refrigerator Feature
  • Deodorizer Type: Yes
  • Number of Door Pocket: 4 EA
  • Fresh room: Yes
  • Big Guards: Yes
  • Number of Shelf (Total): 4 EA (Easy slide + COVER VEG)
  • Egg Container(Egg Tray): Yes
  • Interior LED Light: Yes
  • Shelf Material: Tempered Glass
  • Power Cool Function: Yes
  • Humidity Control (Vegetable&Fruit Drawer): Yes
Freezer Feature
  • Icemaker: Auto Ice Maker
  • Number of Door Pocket: 2 EA
  • Shelf Material: Cool Pack
  • Number of Shelf (Total): 1 EA
General Feature
  • Door Alarm: Yes
  • Compressor: Digital Inverter Compressor
Exterior Feature
  • Display & Control (Fridge and Freezer): Electronic Display
  • Door Handle: Easy recessed handle
  • Colour: Easy Clean Steel
Thank You
Regards,
Jerome
92256638
Brandt 6Kg Top Loading Washing Machine WTC9670 @ $699 * LIMITED SETS ONLY
11c8e4b85c005056ae7b36.jpg?_ex=330x330
Benefits
Delicates, Hand-Washing and Gentle Wool Cycle : Designed to take care of delicates textiles (satins, silks, woollens): the laundry is gently rocked to and fro as if washed by hand with a suitable spin cycle.
  • Automatic weighing system from 1 to 6 kg
  • Recognition of 4 load sizes
  • Spin speed of 700 rpm
  • Temperat ure selector from cold wash to 90°C
  • Prog rammes: OPTIA45', Delicate / wool Hand wash, Rinse Only, spin only, Flash 30'
  • Options: Drip Dry, Pre-wash
  • Sesam' and Posistop opening
  • Safeties: Load balancing system, Anti-overflow, Anti-detergent loss, Door opening safety during washing, Anti-foam
  • Low consumption: 1.14kwh, 52L*
  • Volume of the drum (L) : 42
  • Electrical connections rating (W) : 2250
  • Length of outlet hose (cm) : 135
  • Dimensions of the product HxWxD (mm) : 400x600
  • Dimensions of the packed product (mm) : 970X478X700
Thank you.
Regards,
Jerome
92256638
Edited by zero
Samsung 2 Door Fridge RT32FAR : $630
Enjoy longer-lasting freshness
• Moist Fresh Zone
• Energy saving LED lighting
• Multi Flow
• Easy Slide Out Shelf
Capacity
  • 322 Total Net
  • 72 Net Freezer
  • 250 Net Refrigerator
  • 333 Total Gross Capacity
  • 79 Freezer Gross Capacity
  • 253 Refrigerator Gross Capacity
  • Physical Specifications
  • 600 x 1,715 x 672mm Net (W x H x D)
  • Durability and high quality are synonymous with Samsung's new range of top freezer refrigerator. Backed with a 10-year warranty, the durable Digital Inverter Compressor powerfully, quietly and efficiently cools your food. Other features, such as the Moist Fresh Zone and Multi Flow, keep your vegetables, fruits, and meats fresher for longer periods of time. You’ll also enjoy the convenience of storage innovations such as the Easy Slide Out Shelf for many years to come.
  • Enjoy energy savings, less noise and a 10-year warrantyRT32FARCDSL-SS-35-0.jpg
    Unlike conventional compressors, which have just two patterns of start and stop, Samsung’s Digital Inverter Compressor makes 5 different moving cycle based on humidity levels and usage patterns. This helps maintain a more consistent temperature, reduces wear and tear on the compressor for greater durability, and keeps noise to a minimum. You’ll also enjoy the peace of mind that comes with lower electricity bills and a 10-year warranty guarantee.
    Optimal humidity for longer-lasting freshness
    Fresh vegetables and fruit are good for you, but what’s good for vegetables and fruit? Samsung’s Moist Fresh Zone. The smartly designed drawer provides an ideal environment for apples and zucchini alike, so they stay fresher, longer. A tight seal prevents moisture from escaping when humidity levels are low, and a vent releases excess moisture when humidity levels are too high. Together with the conduction cooling system, these elements maintain the optimal humidity levels to preserve your produce.
    Conveniently maximise your storage space
    Reaching into a refrigerator to grab a tub of yogurt from the back often means navigating an obstacle course of food items! One wrong move could mean squished icing or broken glass on the floor. The Easy Slide shelf is built on rolling hinges, and pulls out so you can efficiently organise and easily access your food items and readily see just what you have store in the back.
    The LED Lighting illuminates with bright light to easily locate the items in the fridge. It emits 10 times less heat than conventional bulb lighting so your food stay fresh for a long time. The semi-permanent LED lighting is 20 times more efficient of the energy to save your money.
    No-Frost Technology Stays in right condition, doesn’t stick together and no ice build up.
Hi, please provide the price of the following;
1) Rinnai RB3SI/RB3CG/RB2CG
2) Fujioh SLM 900 R / Fujioh FX900R
3) Hitachi R-E6800S/R-E6200S
4) Samsung RT53H6377SL
5) Bosch HBN331E2J
Samsung 48" UHD TV 48JU6000 @ $1299 * FREE DELIVERY
Experience more accurate and natural colours
Samsung developed a special colour technology for our UHD TV called PurColour, which expresses a wider range of colours and shades that are as close to real life as it gets, bringing you closer to what nature intended. With all the 8 million pixels that come with a UHD display—four times more than a Full HD display—you need more colour adjustment points to create detailed images. Conventional UHD TVs have about 27 colour adjustment points, but PurColour dramatically increases that by more than 7 times, resulting in colours and shades that are much richer and more refined.
Contrast Enhancer
Flat images come to life with Samsung’s Contrast Enhancer. Your TV intelligently applies varying levels of contrast enhancement to different areas and objects on the screen creating a dramatic 3D-like effect. It’s the most realistic viewing experience possible on a flat screen TV.
4 times the Full HD resolution
Ultra HD viewing means you can see every intricate detail on the screen clearer than ever. Your Samsung UHD TV offers a resolution four times higher than Full HD, with accurate true-to-life colour. Enjoy a picture that’s optimised for even greater clarity and detail than you’ve ever seen before.
Display
Screen Size
48"
Resolution
3,840 x 2,160
Ultra Clear Panel
Ultra Clear
Video
Picture Engine
UHD Up-scaling
Clear Motion Rate
100
Motion Refresh Rate
50
Dynamic Contrast Ratio
Mega Contrast
Micro Dimming
UHD Dimmng
PurColour
Yes
Contrast Enhancer
Yes
Film Mode
Yes
Natural Mode Support
Yes
Audio
Dolby Digital Plus
Yes
Virtual Surround
DTS Studio Sound
DTS Codec
DTS Premium Sound 5.1
Sound Output (RMS)
20W(L:10W, R:10W)
Speaker Type
2CH(Down Firing + Bass Reflex)
HD Audio
Yes
Wallmount Sound Mode
Yes
Tuner/Broadcasting
Digital Broadcasting
DVB-T2
Analog Tuner
Yes
Multiroom Link
Yes
Thank you
Regards,
Jerome
92256638
Edited by zero
Hi Jerome,
Can you please quote for me the following??
kuche KUF-95U Upright freezer
kuche KCF-105Q Chest Freezer
or do you have any freezer that is similar to the above 2 models??
On top of that, im looking for a bedroom smart tv of abt 32" ard $200-$300..
Any recommendations??
regards,
muhammadrozaidi
Hi Zero
Appreciate if u could quote the following
Hood
Fujioh FJS900
Rinnai RH-C779-SB
Hod
Rinnai RB-713N
Fujioh FG 773
Or any glass 3 burner
Washing Machine
Samsung WA10J
Frige
Samsung RT50 TMF
Samsung RT38
Oven
Any to recommend ?
Do u have any shop we can visit ?
Samsung 60" SMART TV 60H6203 @ $1750 ** FREE BLURAY PLAYER while stocks last only!!!
Thank You
Regards,
Jerome
92256638
Hi.can quote me fujioh/rinnai hob and hood packages that is below 900?
May i know what other 2 door fridge with 3 ticks u have also below 1k? Ur pm is full Thanks
Edited by Gaaron
