zero
Panasonic 2 Door Bottom Freezer NRBR347ZSSG @ $649 * FREE $50 NTUC VOUCHERS!
Specifications:
  • Gross Capacity
    • Total: 342.0 L
    • Refrigerator Compartment ( PC ): 250.0 L
    • Freezer Compartment ( FC ): 92.0 L
    • Storage Capacity (ISO 15502): Total 282.0 L
    • Refrigerator Compartment ( PC ): 234.0 L
    • Freezer Compartment ( FC ): 48.0 L
  • Product Dimensions (WxDxH): 600 x 629 x 1725 mm
  • Defrost Type: Automatic defrost
  • Energy Label: 2 Ticks
  • Net Weight: 53 kg
  • Voltage: 220 V - 240 V
  • Hertz: 50 Hz
  • Number of Doors: 2
  • Color: Stainless Color (S)
REFRIGERATOR COMPARTMENT (PC)
  • Tray Material: Glass Tray
  • Crisper (Vegetable Case): Yes
  • Egg tray: Yes (2 pcs)
  • LED Light: Yes
  • Color of Inner Plastic Parts (Cabinet): High clear gray smoke
  • Color of Inner Plastic Parts (Door): Clear gray smoke
  • Adjustable Tray: Yes
FREEZER COMPARTMENT (FC)
  • Twist Ice Tray: Yes
  • Ice Box: Yes
  • Freezer Case Top: Yes
  • Freezer Case Bottom: Yes
OTHERS
  • ECONAVI Yes
  • Door Control Panel Yes
  • Compressor Inverter
  • Refrigerant GAS HFC-134a
  • Urethane Insulation Cyclopentane Yes
  • Ag Clean (Anti Bacteria & Deodorizer) Yes
  • Fresh Safe Yes
Thank you
Regards,
Jerome
92256638
homeappliances@hotmail.sg
Edited by zero
Package Deals @ $1049
Rinnai RB2GI Inner Burner Technology Hob
- Rinnai's Original Combustion Technology
- Save Energy and Cooking Time
- Elegant Knobs
- Air Intake Guard
- 2 Inner Burner Built-In Hob
- Cut-out(mm): 703(W) x 403 (D)
Fujioh FJS900 Chimney Hood
DIMENSIONS (WxDxH)(mm) 900 X 500 X 800-1020 (with extended duct)
Oil Fumes Capture @ 92%
FEATURES
Punch Filter eliminates oily build-ups, and is anti-rust, washable and easy to clean.üTechnologically Advanced Removable Rectifier Panel.
Sirocco Fan.
Oil Catch Tray.
Fire-retardant Body.
Thank you.
Regards,
Jerome
92256638
LG 2 Door 410L Fridge GTB4101PZ @ $849 * FREE DELIVERY
Features:
  • Smart Inverter Compressor
  • Multi Air Flow
  • LED Lighting
  • Moving Ice Tray
Specifications:
Net Capacity
  • Total: 410
  • Refrigerator: 295
  • Freezer: 115
GENERAL FEATURES
  • Inverter Compressor: Yes
  • Refrigerant: R600A
  • Cooling function: Yes
  • Temperature Control: Yes(Electronic Sensor)
  • Door Alarm: Yes
Dimension (MM)
  • Product (Width x Height x Depth): 700 x 1680 x 730
GENERAL INTERIOR FEATURE
  • BioShield™: Yes
FREEZER COMPARTMENT
  • Moving Ice Tray: Yes
  • Tempered Glass: Yes
  • Door basket (Transparent): Yes
  • Refrigerator Shelves: Tempered Glass
  • Pull Out Tray: Yes
  • Door Basket (Transparent): Yes
  • LED Light: Yes
  • Fruit & Vegetable Box: Yes
  • Egg Bank: Yes
  • Humidity Controller: Yes
Thank you.
Regards,
Jerome
92256638
LG 8kg Washer Cum 4kg Dryer WD1486ADP @ $880 * FREE DELIVERY
Features
· 6 MOTION
· INVERTER DIRECT DRIVE SYSTEM
· A+++ ENERGY EFFICIENCY
· BABY CARE
Just Like Hand Wash
When doing laundry, you might have experienced to see the inner drum always tumbles with monotonous motion through the fabric type is different. Don't you think that washing machine should adopt different movement for each fabric type instead of one single tumble motion for different fabrics? LG's new 6 Motion Technology introduces a new way to care for clothes, similar to hand wash. The Direct Drive Motor precisely controls the action of tub, allowing for up to 6 motions in which the washer combines different combinations of wash motions to selected cycle to ensure perfect clean. It's suitable or all fabric types and cares for your delicate clothes.
By eliminating the belt and pulley in conventional washer motors, LG's Direct Drive System increases the motor's stability and lessens vibrations. This gives Direct Drive increased durability, which translates to lower maintenance costs. The motor is more energy efficient too, so you'll have lighter energy bills.
ENERGY SAVING
Sensor detects the loading capacity and calculates the exact rpm and braking time for each operation. The accuracy can ensure optimum washing performance. This not only saves your time, but also water and energy.
Body Type
Front-load
Total Capacity
8/4kg
Spin Speed
1400rpm
Stackable
Yes
Dimensions
600x850x550
Drum and Interior Finish
Stainless-steel
Energy Consumption
A+++ Efficiency
Eco-friendly Certification(s)
MWL (3 ticks)
Eco-friendly Feature(s)
6 motion DD
Available Colours
White
Screen Technology
LED display
Wash Cycle Modes
Cotton, Cotton Eco, Easy Care,Sports Wear, Wool, Quick30, Rinse+Spin,Baby Care, Intensive60, TimeDry
Control Panel
LED
Automatic Temperature Control
Yes
Timers
Available
Dispensers
Detergent, Bleach, Softener
Health Features
Medic Rinse
Water Efficiency
6.10 litres/kg
Noise Reduction
Inverter Direct Drive
Vibration Reduction
Safety Features
Child lock
Indicators
Door Indicator, Inlet, Outlet, Water, Load
Thank you.
Regards,
Jerome
92256638
Edited by zero
Panasonic 10kg Top Load Washer NAF100A1 @ $525 FREE DELIVERY
TECHNICAL DATA :
Load Capacity 10 kg
Dimension(W x D (with hose) x H) 641×695×1034
ECONAVI -WASHING TECHNOLOGY :
Active Foam System yes
Dual Wave Pulsator yes
Dancing Water Flow yes
Aqua Spin Rinse yes
Control panel type In-mold
LED color Amber
Digital Display yes
Delay Start yes (2-24hours)
PROGRAMMES :
Number of Programs 9.0
Normal yes
Speedy yes
Baby-care yes
Comforter yes (Blanket)
Delicate yes
Power Wash + Soak yes
Tub Hygiene yes
Fragrance yes
Air Dry (90 min.) yes
SPECIAL PROGRAM (INDEPENDENT BUTTON) :
Energy save -
Water Save Yes
MANUAL SETTING :
Washing Time yes (3/6/9/12min.)
No. of Rinse yes (1/2/3/Refill)
Spinning Time yes (1/3/5/7min.)
Water Level setting yes (10 levels / 4LED)
OTHER FUNCTIONS :
Child lock (With LED) yes
Advanced auto restart yes
Low water pressure yes
Wider Voltage Operation yes
Auto Power Off yes
Sazanmi Drum yes
Remaining Time Indication yes
Big cassette lint filter yes
Tempered glass lid yes
OUTER DESIGN :
Color (Lid) White
Color (Body) White
Thank you.
Regards,
Jerome
92256638
Winia - MADE IN KOREA air purifier
From $299 - $499 * While stock last
No. 1 best-selling brand in Korea that is sought after by the Korean woman as it do not just clean the air by water but it moisturize their skin.
The positioning of this product is not an opportunity product due to the Singapore Haze issue. This is an innovative & revolutionise product that took Korea by storm.
The principle of purify the air is water
•Winia airwasher inflow contaminated air by rotating disc and bring the air into the water tank, the built-in Bio Silver Stone would kill the germs and bacteria in the water and exhale clean and humid air.
•Bio Silver Stone technology is a unique technology developed by Winia, which is able to kill up to 99.99% of germs in the water tank.
•Winia Plasma System can eliminate H1N1 virus, Nicotine, VOC and dust in the air.
•No Filter required! Only change the Bio Silver Stone by year!
•Control humidity level in between 40-60%! Do not increase humidity if the in-room humidity level is over 60%!
•Using natural humidifying method, will not make the environment become damp!
•Awarded by Health Healthy Humidifier and Korea Atopy Association!
•Certified by Seoul Sleep Research Lab which can improve sleeping quality!
•Silent mode allows to use at night time!
Thank you.
Regards,
Jerome
92256638
Edited by zero
I am looking for a hob with 2 burners and glass top and actually there are too many out there to consider.
can u recommend something abt $400-$450 range for daily user like me.
something that durable too thank you
Dear All,
Kindly Email or Whatsapp for faster response.
Thank you.
Regards,
Jerome
92256638
Samsung Lastest 32" LED TV 32J4303 @ $359 ** LIMITED SETS ONLY
Screen Size 32 inches
- Resolution: HD Ready (1366 x 768px)
- The 100Hz CMR motion clarity
- HyperReal Engine picture technology
- Technology Premium Sound audio DTS 5.1, DTS Studio Sound, Dolby MS10
- videos, content backup via USB
- 3 Protection (moisture-proof, anti-shock, anti-lightning)
- Internet TV - Integrated WiFi
- Connectors Component Video (Y / Pb / Pr), HDMI , DVI, USB
Thank you.
Regards,
Jerome
92256638
Hi please kindly quote me for the following:
Hood/hod/Oven
1) Brandt Hood: AD-995XC, Brandt HOB: TG 1483B
2) TECHNO TBO-630 oven/ Techno TMO28 oven
3) Bosh HBN331E2J Oven
Storage heater
1) 35L Joven storage heater
Washing Machine:
1) Samsung Top load Washer (9kg) WA90F5S9
Fridge:
1) Samsung RT5982, 560L
Vacuum:
1) Electrolux E360PT-with vacuum bag type
Rice Cooker:
1) Panasonic SR-MG182
TV:
Samsung 40 & 48 Inch ultra HD smart LED TV JU6400
Edited by tkc01
Baron Water Closet W888 @ $2XX ! LIMITED SETS ONLY!
Description
Washdown Water Closet
Slow Moving Seat Cover
Urea Seat Cover - UF05/UF06
SIZE: 150mm, 250mm & 300mm
P-TRAP
Smooth Flushing System
Water-saving
PSB Approval
Geberit Fitting
Thank you.
Regards,
Jerome
92256638
limited sets only!
