zero
KDK 3 Blade Ceiling Fan - 44Inch Best for All BTO!
PRICE :$ 179
  • Ceiling Fan 110cm w/ Remote Ctrl
  • For HDB Apartment/Apartment with Low Ceiling (2.6 metres to 3 metres)
  • Wireless remote control
  • 44-inch blade span, 3-speed selection
  • 1, 3, 6-hour timer, sleep mode
  • Blade made of rigid ABS material with painting
  • Thermal fuse prevent overheating or power surge
  • Safety Wire provided
  • Cut-Off safety switch equipped
  • Fall prevention of blade adopted
  • Permanently lubricated ball-bearing assembly
  • Colours: White or Silver
Thank you.
Regards,
Jerome
92256638
homeappliances@hotmail.sg
Edited by zero
Hi Jerome
can I get a quote for:
Fuijioh 3773 SVSS
Fujioh FS 890 R
Joven JH25HE and JH35HE
is there any promotion for Baron WC888?
Can I get a quote for the following Crestar fans:
- CSL105 Skylite plus (50″) Polycarbonate; Black; with remote control; with 20W LED Panel (Tri-Color)
- CSL03 iCol (46″) Polycarbonate; White; with remote control; with 18W Tri-Colour LED Light
ARINO WC-CAPRIO-WT @ $368 *FREE DELIVERY!
WC-CARPRIO-WT Carprio Washdown Water Closet
  • Size: 700 x 380 x 855mm
    S-Trap 150, 250, 300mm Roughing-in
    P-Trap 180mm Roughing-in
    Comes with:
  • Geberit Fitting Dual Flush System
  • PP or Urea Wrap Around Soft Close Seat
    PUB Registration No: WC-2009/002433
  • WELs: 3 Ticks
Thank you.
Regards,
Jerome
92256638
Can I get quote of
Cooker Hood with high suction Power but slim hood and price?
Cooker Hob 2 bunner glass surface?
Hitachi Fridge approximately 700-800mm length, 450-500 Litre capacity?
Hitachi washer 8.5kg (without touch screen, belt motor)
Any heater recommend?
Hi Jerome!
Can I have a quote for the below?
Bosch washing machine
1) 8kg: Serie 6 WAP24260SG (1200rpm)
2) 8kg: Serie 6 WAP20160SG (1000rpm)
3) 7kg: Serie 4 WAK24160SG(1200rpm)
4) 7kg: Serie 4 WAK20060SG (1000rpm)
TV
1) LG 55UF770
2) LG 55UG870
Fridge
1) LG GBB5191pz
Hood
1) Fujioh SLM 600
2) Fujioh SLM 900
Rice cooker
1) JBAA10S
Dyson fan (MBR)
1) AM08
Can quote the following:
1) Fujioh Hood Fx900
2) Fujioh Hob FG3773 SVSS
3) Rinnai RB-3VSVA
4) Bosch Oven HBN331E2J
Please share the quote for:
Hob
- Rinnai RB-7302S-GBS
- Rinnai RB-7502D-GBSM
- Rinnai RB-29FV(B)
- Rinnai RB-712N (G)
- EF EFH 7620 TN VGB
Hood
- Rinnai RH-S239-SSR
- EF EFCH 9202 HM SS
And can you advise which do you recommend?
Edited by Nex24
Any Electrolux EHC726BA induction cooker user here? Would like to know how big is the heating elements, ie what are the right pans sizes for the 2 heating zone?
Am considering between this and Bosch PMI938MS induction cooker (both are 2 zones) - any reviews/ comments on which is better? Customer service (ok, my experience with services in Singapore is terrible!) between Bosch and Electrolux - which is better/ worst? Anyone with experience to share?
Fridge - choosing between Samsung and LG around 450L capacity. Any recommendation?
Side by Side Fridge Made in Europe, 3years Local Parts and Labour Warranty! Limited First 10 Sets offer!
Retail Price : $1588
NOW : $1280
beko-asl141s-610l-side-by-side-refrigera
  • Active Dual Cooling System
  • Active Odour Filter with Seal Guard - This filters the circulated cool air inside the refrigerator and eliminates unwanted odours and bacteria to help keep the food inside fresh.
  • Active Fresh Blue Light
  • Electronic Touch Display
  • NeoFrost - Thanks to the fan in the fridge section of selected Beko fridge freezers, cold air will be circulated in the fridge more evenly, thus ensuring a better cooling performance.
Cabinet Depth (cm) 71.0 cm
Cabinet Width (cm) 92.0 cm
Cabinet Height (cm) 179.0 cm
Thank you.
Regards,
Jerome
92256638
Edited by zero
