zero
Samsung 2 door Fridge RT46H5200 @ $ 9XX
Product Features
Durability Guaranteed
Backed by a 10-year warranty (compressor only), Samsung guarantees the durability of its Digital Inverter Compressor.
Instead of constantly switching between on and off, this durable and energy efficient compressor is always active, automatically adjusting its speed in response to cooling demand across 7 levels. The result is less wear and tear of your refrigerator for trouble-free, longer-lasting performance.
Evenly cools every corner
All-Around Cooling enables everything fresh by cooling every inch of the fridge evenly from corner to corner. Cold air is blown out through multiple outlets at every shelf level, maintaining an even and constant temperature from top to bottom and food stays longer.
Easy to find and reach
Getting food out of a refrigerator often means navigating an obstacle course of items. RT6000 refrigerator's Easy Slide Shelf which simply slides in and out helps you to efficiently store, organise and access your groceries-quickly and easily reaching things right at the back and in every corner.
Specifications
Capacity Net Total(Liter)
  • 460ℓ
Net for Freezer(Liter)
  • 112ℓ
Net for Refrigerator(Liter)
  • 348ℓ
Gross Total(Liter)
  • 472ℓ
Gross for Freezer(Liter)
  • 123ℓ
Gross for Refrigerator(Liter)
  • 349ℓ
Cooling Feature Cooling Type
  • All-Around Cooling
Physical specification Net Dimension (WxHxD)(mm)
  • 700 x 1,825 x 726
Net Width(mm)
  • 700mm
Net Case Height with Hinge(mm)
  • 1,825mm
Net Depth with Door Handle(mm)
  • 726mm
Net Depth without Door Handle(mm)
  • 726mm
Net Depth without Door(mm)
  • 615mm
Refrigerator Feature Deodorizer Type
  • Deodorizer
Humidity Control (Drawer Only)
  • Moist Fresh Zone
Shelf Material
  • Tempered Glass
Thank You.
Regards,
Jerome
92256638
homeappliances@hotmail.sg
Edited by zero
German Brand Granite Sink and Tap @ $ 268 * limited to first 10sets only!
* 3 Color of sink to choose from, Black, White, Grey!
Thank you.
Regards,
Jerome
92256638
Edited by zero
Crestar 46" Ceiling Fan with Remote Control !
Color : Black, White, Silver, bronze !
Price : $270
Motor Crestar 153 Super Alumi motor
Speed Low/Medium/High
Blade 3D Double Angle HY Blade
RPM 180-245
Thank you.
Regards,
Jerome
92256638
Edited by zero
Hi Jerome,
Please quote me for the following, TIA!
1) Fridge - Hitachi RVG690P3MS 550L
2) Washing Machine - Samsung 9kg WA-90F5S5QWA
3) Hood - Fujioh FS890
4) Hob - FG2792SVGL
5) Water Heater - 707 Princeton
6) Ceiling Fan - Fanco FFM 200
Cheers!
For Selected Models only!!!
FREE $10 Choice vouchers with every purchase, While stocks last!!
Thank you.
Regards,
Jerome
92256638
Homeappliances@hotmail.sg
Ariston Made in Italy Oven FH52IX @ $5XX
  • 5 cooking programs:
.Traditional
.Multi-cooking
.Gratin
.Grill
.Upper heating
.gratin(fan grill)
.pizza
.fast cooking
.barbeque.cake
.low temperature (meat, fish,vegetables)
  • Tangential ventilation
  • Rotisserie
  • Thermostat control
  • Oven accessories: dripping tray and grid
  • Energy efficiency: Class A
Thank you.
Regards,
Jerome
92256638
Samsung 48H6400 : $1290 * Limited sets only!
  • Samsung H6400 Smart LED TV Delivers both Vivid Color and Dramatic Contrast.
  • Upgraded Smart Hub is Easier to Use and More Intuitive than Ever.
  • Discover Whiter Whites and Deeper Blacks with Micro Dimming.
  • Enjoy Amazing Image Clarity with 1080p Full HD Resolution.
Thank you.
Regards,
Jerome
92256638
Edited by zero
Pls quote the following items. Thks!
1) Hitachi RD6200S
2) Hitachi RD6800S
3) Mitsubishi MRJX64
Electrolux 6.5kg washer EWP85662 : $539 * 3sets only!
Front-load washer
Total Capacity Washing Capacity: 6.5kg
Number of Wash Cycles 14
Spin Speed 850 rpm
Stackable Yes
Dimensions 600 x 850 x 582
Wash Cycle Modes Cottons (90 degree) / Cottons (60 degree)/Cottons (40 degree) / Cottons (Cold)
Synthetics (60 degree) / Synthetics (40 degree) Synthetics (cold) / Delicates (40 degree) /
Delicates (cold) / Handwash (30 degree) Handwash (cold) / Rinse / Drain / Spin
Water Efficiency Water efficiency (WELS) - 3 ticks Water consumption: 8.80 L/k
Quick Menu Options Spin Hold, Prewash, Economy, Quick, Extra Rinse
Warranty 2 years warranty
Thank you.
Regards,
Jerome
92256638
Fisher & Paykel Fridge E522BRXFDU3 : $2250
PRODUCT INFO
Active Smart technology has been given a new addition, an integrated water dispenser providing you with chilled filtered water and an internal ice maker for clean, crisp ice cubes on demand. With no impact on space in the freezer or refrigerator door, this is the perfect addition to the Active Smart family
FINISHES
  • EZKleen Stainless Steel
CONFIGURATION
CONSUMPTION DATA
  • Energy usage (kWh/yr)569
DESIGN
Edited by zero
Can you quote me the Mitsubishi MR Z65W white model. Please let me know the payment term as well.
your inbox is full, pls email or whatsapp me.
Thank you.
Regards,
Jerome
92256638
Hi Zero
1. Fujioh Black Glass Cooker Hob / Model No: FG773 SVGL
2. Fujioh Kitchen Cooker Hood / Model No: FX900
3. Ariston built-in Oven FH521XS
4.Bosch built-in Oven HBN331E2J
5.Ariston Ti-Shape Series Storage Heater Ti-shape 30L/SGHP 30UE SIN 1.5
6 Amasco ceiling fan 52 elegant
Edited by hope
Hitachi 8.5kg Auto Self Clean Front Load Washing Machine BDW85TA : $8XX
Key Highlights
  • Auto Self Clean
  • 1,200r/min Spin Speed
  • 3D Sensor Control Wash
  • Dual Vibration Control System
  • Intelligent Sensor Systems
  • LED Multi Function Display
  • Standby Power Zero W
  • Auto Power Off
  • Fully Auto Restart
  • 600(H) x 850(H) x 600(D),mm
Thank you.
Regards,
Jerome
92256638
Edited by zero
