zero
Hi, Can provide quote for the below?
Mitsubishi StarMex Inverter System 3
Outdoor unit - MXY-3A28VA
Indoor unit - MSY-GE18VA
2 trip installation
Armaflex Class “O” 1/2 inch thick insulation
G23 Copper Pipe
Kkeystone Flexible Wire Cable
16mm drainage pipe
Panasonic Washing Machine
NA-F90G3
NA-F90S3
NA-F80S3
Warranty and Price
Jovan Storage Water Heater
JVA Vertical Series - JVA25
Green Storage Water Heater - JH 25 HE
JH Horizontal Series - JH 25
Installation, Warranty and Price
Mitsubishi Refregerators
MR-E52S (Elegant Champagne colour)
MR-F51C (Pearl Black colour)
MR-V45C (Pearl Black colour)
MR-F47C (Pearl Black colour)
Warranty and Price
Hi, any advise on the quotation above?
2 trip installation
G23 Copper Pipe
16mm drainage pipe
NA-F90G3
NA-F90S3
NA-F80S3
Warranty and Price
Warranty and Price
Hi, Can provide me the quote for the below?
Mitsubishi StarMex Inverter System 3 Warranty and Price Outdoor unit - MXY-3A28VA 2 trip installation Indoor unit - MSY-GE18VA Armaflex Class “O” 1/2 inch thick insulation G23 Copper Pipe Kkeystone Flexible Wire Cable 16mm drainage pipe Panasonic Washing Machine NA-F90G3 NA-F90S3 Warranty and Price NA-F80S3 Warranty and Price Jovan Storage Water Heater JVA Vertical Series - JVA25 Warranty and Price Green Storage Water Heater - JH 25 HE Warranty and Price JH Horizontal Series - JH 25 Warranty and Price Mitsubishi Refregerators MR-E52S (Elegant Champagne colour) Warranty and Price MR-F51C (Pearl Black colour) Warranty and Price MR-V45C (Pearl Black colour) Warranty and Price MR-F47C (Pearl Black colour) Warranty and Price
Electrolux 7Kg Dryer EDV7051 : $480 * Limited Sets !!!
Description:
new Venting Dryer
Have peace of mind knowing that your clothes will be perfectly dry, be it rain or shine. A modern solution to age old laundry problems.
USP:
Sensor Dry – detects moisture level in the laundry and stops the drying once the laundry is dried to prevent over-drying and to save energy
Dryness Selection – select your preferred level of dryness for your laundry
Flexible Installation – these dryers can be placed side-by-side, stacked or wall-mounted above your washing machine
Crease Free option – the drum periodically rotates after the drying cycle has finished which helps to reduce wrinkles
Features & Specifications:
Model: EDV7051
Description: 7kg Electronic Control Venting Dryer
General Specifications:
Drying Capacity: 7kg
Product Dimension (WHD) mm: 600 x 845 x 620
Features:
Drying Technology: Vented
Auto Sensing: Yes
Temperature Control: 3 levels
(Normal, Delicate, Airing)
Time Drying: 90/60/30 mins
Dryness Selection: 3 levels
(Extra Dry,Normal Dry, Iron Dry)
Drying Options: Crease Free
Exhaust Outlet: Front or Back
Delay Start: 9/6/3 hours
Display: LED Indicator
Clean Filter Indicator: Yes
Wall Mount Installation: Yes
Buzzer Option: Yes
Child Lock safety: Control Panel & Door
Accessories: Venting kit & Wall mount kit
Technical Specifications:
Voltage (V): 220-240
Frequency (Hz): 50
Power (W): 2250
Gross Weight (kg): 32
Samsung Fridge RL4013 @ $950 * Limited sets only!!!
Product Features
See All
Designed to help save money — and the environment
Preserve food and the environment at the same time. The new Samsung refrigerator uses 20% less energy than conventional models. This refrigerator uses new energy-efficient technologies help conserve energy.
Intelligent cooling for optimal efficiency
Designed to optimise the refrigerator’s cooling performance, the Smart Sensor System uses five sensors to monitor the temperature in your kitchen and the humidity level inside the fridge.
Enjoy energy savings, quiet time and a 10-year warranty
Samsung’s Digital Inverter Compressor makes slight adjustments based on humidity levels and usage patterns. This helps maintain a more consistent temperature and reduces wear and tear on the compressor.
Specifications
See All
Capacity Gross Total(Liter)
  • 450ℓ
Net Total(Liter)
  • 380ℓ
Net for Freezer(Liter)
  • 81ℓ
Net for Fridge(Liter)
  • 299ℓ
Refrigerator Feature Number of Shelf (Total)
  • 4EA
Physical specification Net Dimension (WxHxD)(mm)
  • 700*1700*746.6
Net Width(mm)
  • 700mm
Net Case Height with Hinge(mm)
  • 1700mm
Net Case Height without Hinge(mm)
  • 1668mm
Net Depth with Door Handle(mm)
  • 746.6mm
Net Depth without Door Handle(mm)
  • 705mm
Net Depth without Door(mm)
  • 600mm
Hi Jerome, is this model still available? Can quote me your price and advise the delivery and payment procedure please?
My email is sharonhls@gmail.com.
<p><p>
Samsung Side by Side Fridge
Price : $11XX
Modernly designed to
optimise performance
Premium design for modern kitchen
Twin Cooling System
Energy saving LED lighting
Product Features
Premium design for the modern kitchen
Recessed handles and hidden hinges provide a touch of elegant minimalism that complements any modern decor.
Twin Cooling System gives you the best of both worlds
The RS554 uses two separate air flows and precise temperature control to maintain optimal humidity levels on both the refrigerator and freezer sides.
Preserves your food longer, keeps your electric bills lower
The innovative Digital Inverter Compressor saves energy with nine sensors that track temperature and humidity levels and help optimise the fridges performance.
Specifications
Capacity
  • 538 Liters Total Capacity (Net)
  • 199 Liters Freezer (Net)
  • 339 Liters Fridge (Net)
  • Drawer x 2ea
  • Door Pocket x 4ea
  • Egg Tray container
  • Shelf x 5ea
  • Tempered Glass Shelf x 4ea
  • Spill-Proof Shelves available
  • Deodoriser available
  • LED
Performance
  • 4 star freezer energy rating
  • 4 tick energy grade
Category
  • Side By Side Refrigerator Type
Cooling Feature
  • Twin Cooling System
  • No Frost feature
  • Multi Flow feature
Freezer Feature
  • Twist Ice Maker
  • Drawer x 3ea
  • Shelf x 4ea
  • Door Pocket x 5ea
  • LED
  • Half Hidden Handle
  • Shiny River White (Glass)
Others
  • Door Alam available
  • R600a Refrigerent available
  • Cyclopentane Insulation available
Physical Specifications
  • 912 x 1,789 x 700mm Net Dimension
  • 1,789mm Net Case Height with Hinge
  • 1,789mm Net Case Height without Hinge
  • 700mm Net Depth with Door Handle
  • 117kg Net Weight
Hi Jerome,
Can you quote me the following items:
HOBZ Hood - HH-6922 ss
HOBZ Hob - HG-1883 BK
HOBZ Oven - HO-82 SS
Rinnai Storage Heater - 35L & 50L capacity
Rheem Storage Heater - 35L & 50L capacity
Samsung Washer Cum Dryer WD702 : $850
Samsung WD702 front load washing machine that gets more out of your laundry detergent with the new Samsung washer with Ecobubble technology. Inside is a unique bubble generator that dissolves detergent thoroughly and injects it with air to produce a rich, soapy foam. Even at cooler temperatures, this foam penetrates fabrics faster than in conventional washers, cleaning as effectively as a warm standard cycle. The result? A gentle clean that saves energy.
Features Eco Bubble Technology Breakthrough Ecobubble technology froths up detergent with air and water before the cycle begins, generating cleansing bubbles that penetrate fabrics faster than concentrated detergent. Wash clothes as effectively in cool water as you would in warm water. The cool water is gentle on your clothes and protects water-repellent fabrics.
* Tested in accordance with IEC 60456 Ed.5/4kg Wash Load / Super Eco Wash cold vs. Cotton 40 Degree without Eco Bubble (WF906). Individual results may vary.
Digital Inverter Motor
The digital inverter motor is brushless, so it runs much cooler and uses less energy than motors found in conventional washing machines.
Ceramic Heating for power and efficiency
Prevent calcium compound build-up, which absorbs more electricity. The quick-heating ability o of ceramic heaters also increased energy efficiency, translating into cost savings on your next electricity bill.
IP068359-Sasmung-Washer-Dryer-WD702U4BKW
Diamond Drum
Samsung’s Eco Bubble Washing Machine features unique Diamond Drum Technology, which replaces the typical washing drum with one covered in deep, diamond-shaped depressions. The small and smooth exit holes minimise wear and tear, and keep your fabrics safe from snags, creating a gentle but effective wash.
Body Type Front Load Total Capacity 7kg(wash) / 5kg(Dry)
Number of Wash Cycles 5
Spin Speed 1400rpm
Dimensions 600 x 850 x 550
Water Consumption :6.50litres/kg
Warranty 2 yrs (Parts and labour) 11 years Motor
Thank you.
Regards,
Jerome
92256638
homeappliances@hotmail.sg
Edited by zero
Samsung Fridge RT35FDA : $699 * Limited sets only!
Enjoy longer-lasting freshness
• Moist Fresh Zone
• Energy saving LED lighting
• Multi Flow
• Easy Slide Out Shelf
Capacity
  • 363 Total Net
  • 87 Net Freezer
  • 276 Net Refrigerator
  • Physical Specifications
  • 675 x 1,715 x 668mm Net (W x H x D)
Durability and high quality are synonymous with Samsung's new range of top freezer refrigerator. Backed with a 10-year warranty, the durable Digital Inverter Compressor powerfully, quietly and efficiently cools your food. Other features, such as the Moist Fresh Zone and Multi Flow, keep your vegetables, fruits, and meats fresher for longer periods of time. You’ll also enjoy the convenience of storage innovations such as the Easy Slide Out Shelf for many years to come.
Enjoy energy savings, less noise and a 10-year warranty RT35FDACDSL-SS-62-0.jpg
Unlike conventional compressors, which have just two patterns of start and stop, Samsung’s Digital Inverter Compressor makes 5 different moving cycle based on humidity levels and usage patterns. This helps maintain a more consistent temperature, reduces wear and tear on the compressor for greater durability, and keeps noise to a minimum. You’ll also enjoy the peace of mind that comes with lower electricity bills and a 10-year warranty guarantee.
Optimal humidity for longer-lasting freshness
Fresh vegetables and fruit are good for you, but what’s good for vegetables and fruit? Samsung’s Moist Fresh Zone. The smartly designed drawer provides an ideal environment for apples and zucchini alike, so they stay fresher, longer. A tight seal prevents moisture from escaping when humidity levels are low, and a vent releases excess moisture when humidity levels are too high. Together with the conduction cooling system, these elements maintain the optimal humidity levels to preserve your fresh produce.
Conveniently maximise your storage space
Reaching into a refrigerator to grab a tub of yogurt from the back often means navigating an obstacle course of food items! One wrong move could mean squished icing or broken glass on the floor. The Easy Slide Out shelf is built on rolling hinges, and pulls out so you can efficiently organise and easily access your food items and readily see just what you have store in the back.
The LED Lighting illuminates with bright light to easily locate the items in the fridge. It emits 10 times less heat than conventional bulb lighting so your food stay fresh for a long time. The semi-permanent LED lighting is 20 times more efficient of the energy to save your money.
Thank you.
Regards,
Jerome
92256638
Edited by zero
Samsung 46' 46H5303 LED TV @ $850 * FREE DELIVERY AND WALL MOUNT
*NEW Model, 3years Samsung SG warranty.
samsung-48h5500-400x400-imadvv7suyfekhcb
Screen Size 46 inches
- Resolution: FHD (1920 x 1080px)
- The 100Hz CMR motion clarity
- HyperReal Engine picture technology
- Technology Premium Sound audio DTS 5.1, DTS Studio Sound, Dolby MS10
- videos, content backup via USB
- 3 Protection (moisture-proof, anti-shock, anti-lightning)
- Internet TV - Integrated WiFi
- Connectors Component Video (Y / Pb / Pr), HDMI , DVI, USB
Thank you.
Regards,
Jerome
92256638
Hi Zero,
Would appreciate if you could quote me the price for Rinnai RB-2CG. Does the price includes installation?? And as of currently, when's the earliest date for delivery & installation?? Many thanks. =)
Electrolux 8kg EWF10842 front load washer @ $869* while stock last.
Thank you
Regards,
Jerome
92256638
Homeappliances@hotmail.sg
Samsung WA11F5S9 top load 11kg inverter washer.
Price : $790 * limited 3pc only.
Regards,
Jerome
92256638
