ursuladeux
House Facing Direction
I have read contradicting opinions about how to decide the direction that your house/apartment faces, for fengshui reasons I want to know which direction is my house facing.
For e.g. the house facing direction will be the one where you stand inside and look out thru the main entrance. Is this true and applicable for apartments too?
Amateurs like me sure cannot handle something as profound as this.
Better spend some money and get peace of mind than to pick up the pieces later.
The damage can be costly, and I don't mean financially.
Happy CNY.
You can pick up some Fengshui books in stores .
Some expert take readings :
  • From the building orientation
  • From the building main door
  • From the individual unit orientation
  • From the individual unit main door .
Completely ignore the "comtemporary" theories and theorists on door facing issue. You'll find no conclusion till yr last breath.
Try understand why ppls in northern semiphere prefer N-S facing. The same applies for those live in southern semiphere. Note: N-S means airflow through N to S or S to N. This is more than enough on "direction" stuff for FS.
http://www.renotalk.com/forum/index.php?showtopic=25191&view=findpost&p=565756
