littletiger
Reasonable Quotation?
Just bought a resale condo and need some advice on renovation. Is the quotation reasonable?
Kitchen 3.5mx2.5m
toilet 2.5m*2m
A DEMOLITION WORK
1 Hacking of kitchen wall tiles 450$
2 Hacking of common toilet floor tiles 250$
3 Hacking of common toilet wall tiles 450$
4 Hacking of wall between yard & toilet 280$
5 Demolition of door & frame for backyard toilet 120$
6 Hack existing fittings & accessories in both toilets - vanity / toilet bowl / shower screen 200$
7 Dismantle / disposal of existing kitchen cabinet 200$
B MASORY WORKS ( SUPPLY & LAY )( TILES UP TO $3 PSF )
1 Waterproofing membrane in common bathroom 180$
2 Non-slip homogeneous floor tiles in common bathroom 480$
3 Ceramic wall tiles in common bathroom 1,350$
4 Shower kerb for shower area in common bathroom 150$
5 Ceramic wall tiles for kitchen 2,200$
6 Non-slip homogeneous floor tiles for backyard toilet 480$
7 Make good wall & ceiing item A4 & A5 360$
C WINDOW / GRILLES / GLASS / MIRROR WORKS ( SUPPLY & INSTALL )
1 10mm tempered glass shower screen in common toilet ( corner entry ) 650$
2 10mm tempered glass fixed panel in master toilet 260$
3 Full height mirror at dining wall 680$
4 Top hung window with fixed panel in common bathroom 250$
5 Aluminum grilles in service yard 190$
6 10mm tempered glass fixed panel in between kitchen & service yard 180$
D CARPENTRY
1 Kitchen cabinet with ABS trimming & laminate finish 3,520$
- stainless steel dish drainer
- 2 nos. frosted door with laminate frame
2 Solid surface kitchen top 1,200$
3 Suspended vanity with cabinet in common toilet 820$
- abs trimming & laminate finish
- Solid surface table top
- full height mirror
4 Vanity with cabinet in master toilet 680$
5 Replace 18 nos. wardrobe handle 120$
6 Suspended tv console with feature wall in laminate finish 6ft 1,800$
E PAINTING WORKS
1 Painting of whole house wall & ceiling 1,380$
2 Varnish all doors / frames 560$
F PLUMBING WORKS
1 Supply and lay outlet piping for kitchen sink 80$
2 Supply and lay outlet piping for 2 toilets basin 120$
3 Labour to install kitchen sink & tap 180$
4 Labour to install 2 toilets mirror accessories 90$
5 Labour to install 1 no. storage water heater 150$
6 Supply labour to install 2 sets of WC 200$
7 Supply labour to install 2 sets of water basins and taps 160$
G GENERAL
1 Polising of existing marble floor in living / dining hall 580$
2 Supply and lay corrugated cardboard to protect existing flooring 180$
3 Acid wash and general cleaning 250$
4 Disposal of renovation debris 300$
5 Haulage services 350$
H ELECTRICAL WORKS ( estimate )
1 Add 1 no. light point 35$ x 5 175$
2 Install 1 no. light ( normal ceiling or L-box ) 10$ x 10 100$
3 Install 1 no. hanging light 45$ x
4 Add / shift 1 no. single socket power outlet 50$ x
5 Add / shift 1 no. double socket power outlet 60$ x
6 Add 1 no. scv point 120$ x
I OPTIONAL ITEM
1 Change new piping in common toilet ( concealed ) 750$
Total 23,190$
TS,
dun mind if I ride on your thread. If you mind I wld gladly move out. Just trying to save opening a new thread.
Hi All
Got a quote for the repair/reno of 2 toilets. Wonder if its reasonable. Tks
2nd Storey toilet:
To hack existing bathtub, basin, floor tiles with dispose. $500.00
To apply water proofing membrane on the floor. 300.00
To supply and lay new wall and floor tiles. $3500.00
To construct new ceiling board. $300.00
To supply labour to install toilet bowl and basin. $200.00
To supply and install 1 set of tamper glass shower screen. $800.00
3rd Storey toilet:
To apply water proofing membrane on the floor. $300.00
(Optional)
Additional item:
To hack existing wall tiles with dispose. (1 x toilet) $500.00
To replace existing pipe. (conceal) (1 x toilet) $900.00
hi,
no sure the size of your toilet.
But usually the cost of laying new tile HDB toilet flooring include water proofing should be around the range of $450 to $600.
And the shower screen a bit expensive, should be around the range of $400 to $600 for 10mm tempered glass.
If you intereted i can pm you my contractor contact.
Try to get more quote to compare.
Cheers!!
TS,
Hi All
2nd Storey toilet:
3rd Storey toilet:
(Optional)
Additional item:
Hi Jadens,
Sure appreciate that tks.
hi,
Cheers!!
hi,
Cheers!!
if its private property of bungalows, i am sure the toilets are big. And the price of the tiles psf are not stated. If choose marble which cost $20-$50 psf, having toilet reno costing $3000 is quite normal.
Yup agree with that.
Must check on the material to be use.
