mesherry
Can Someone Help Me To Review My Quote?
I bought a 3NG, a total a 796sqft. This is the quotation that i might wan to sign with the ID house, but let me know whether it looks ok, reasonable or something fishy is going on.
I didnt do my kitchen and toilet wall tiles as to save some budget for other things, which could cost another $4000. your help is much appreciated!
Living, Store, 2 Bedrooms & Utility Room
Hacking of existing flooring (Living, Dining, Passageway & Store) $342.00
Hacking of existing flooring (2 Bedrooms) $450.00
Hacking of existing flooring (Utility Room) $90.00
Hacking of wall between MBR and Store $300.00
Seal up existing entrance at store room w/ Partition Board + Rock wool $160.00
Supply & lay 600x600 polished homogeneous floor tiles c/w skirting $3,500.00
Kitchen
Hacking of existing wall between living & kitchen $400.00
Hacking of existing floor & wall tiles $333.00
Hacking of existing cement mortar base $120.00
Construct 2" thick concrete base for fridge, washing m/c & cabinet $250.00
base c/w tiles finish (Washing m/c base area < 20sqft)
Supply & change 1 no. stainless steel flat rubbish chute $100.00
To supply & lay HDB approved extruded foam not exceeding 30sqft $310.00
Supply & apply waterproofing membrance at kitchen $200.00
To connect in/outlet UPVC piping for sink & washing m/c $100.00
Supply & lay homogeneous floor tiles ($3.20 psf app 140sqft) $1,200.00
Supply & install Paint Glass Backsplash (< 11'L) $680.00
To make good wall after hacking wall between kitchen & living rm $200.00
2 nos Toilets
Hacking of existing floor tiles, fittings, accessories & door frames $140.00
Supply & lay waterproofing membrane to 2 toilets $200.00
Supply & lay homogeneous floor tiles to both toilets $760.00
Construct 2 nos shower kerb w/ tiles finish in both toilets $100.00
Supply & install 2 nos frameless glass door for both toilets $970.00
Plumbing Works
Supply & replace stainless steel piping for kitchen & 2 bathrooms (cold point) $550.00
Supply labour to install 2 sets of sitting water closets c/w dual flush & soft close cover $150.00
Supply labour to install 2 no. of wash basins and taps $120.00
Hot point 6 nos (2 MBR toilet, 2 Common Toilet, 1 Kitchen, 1 Washing m/c) $225.00
Supply labour to install 2 sets of bathroom accessories $120.00
Supply labour to install kitchen sink & tap $70.00
Painting Works / Plastering
To paint whole house (interior walls & celing), using ICI or Nippon Emulsion paint (5+1 colours) $1,000.00
To paint all door frames, gate & piping using ICI or Nippon Enamel paint together wt above
Plastering for whole house (+$400 for kitchen) $1,200.00
Ceiling Works
Construct false ceiling at passage way $55.00
Construct false ceiling at WIW $85.00
Construct false ceiling at Dining area $325.00
Construct false ceiling c/w cove light for living area $550.00
Construct false ceiling c/w cove light for MBR $640.00
To supply & install Fibre Plaster to box up piping in Living & Kitchen $250.00
Carpentry Works
Design & fabricate WIW w/o doors interior colour PVC (not exceeding 9') $2,250.00
Construct partition wall for pocket door @ entrance WIW $185.00
Design & fabricate pocket door w/ laminate finish @ WIW entrance (not exceeding 4') $780.00
Design & fabricate 11ft Top kitchen cabinet (laminated) w/ ABS trimming $1,320.00
Design & fabricate 15ft Bottom kitchen cabinet (laminated) +ABS with CERA solid surface counter top $3,150.00
Design & fabricate 5ft full height storage cabinet (laminated) $1,100.00
Supply & install stainless steel dish drainer $100.00
Electrical Works (Provisional)
Supply & Install Double Power pt 9 nos @ $55/no $495.00
Supply & Install Single Power pt 2 nos @ $45/no $90.00
Supply & iInstal Telephone pt 3 nos @ $45/no $135.00
Supply & Install Aircon pt 1 no @ $90/no $90.00
Supply & Install heater pt 1 no @ $90/no $90.00
Supply & Install Hood pt 1 no @ $45/no $45.00
Supply & Install SCV pt 3 nos @ $90/no $270.00
Supply & install Lighting points 9 nos @ $38/no $342.00
Supply & install LAN pt 4 nos @ $25/no $100.00
Supply & install Ceiling Fan pt @ $38/no $38.00
Supply & install DB 1 no @ $350/no $350.00
Miscellaneous
Protection of flooring with corrugated cardboard for affected areas (Lumsum as below)
Chemical washing for whole house (Lumsum as below)
General cleaning upon completion of works (Lumsum as below)
Haulage service (Lumsum as below)
Disposal of renovation debris $600.00
To seal the window area above bedrooms doors $100.00
change bedrooms doors $360.00
To seal the master bedroom aircond $100.00
Construct Half Ht wall not exceeding 5.5' $200.00
total $28,535.00
i really wonder how can hacking be individually priced. My reno guy told me its by lumpsum. So surprised to see 1 item as $333, another is $342. Anyhow 'bong' the amount? Also, how come hack kitchen floor, the base don't just kena hacked at same time? why billed separately? Which renovation is this????
It reminds of a reno firm that quote- hack toilet bowl, hack basin. Already got hacked wall tiles, don't all these automatically fall off from the wall? So can i say don't remove the basin & toilet bowl but only the tiles, so tat i do not need to pay installation fees? lol.
Actually, the quotation is far over priced... they are charging you things that is done free w others....
My advise to skip this company... Super over priced...
i think otherwise, total hacking is $2175 which is not too bad... just that the way it was written until too detailed. other stuff that are by ft, all looks ok to me... some more ex and some cheaper but overall, still ok
i'm a newbie here as well. Is this supply and installation of lighting points at $38 each, including providing the downlights? everything all in included?
My ID quoted me $40 per light point installation, but the quotation included a statement of owner to provide own lighting. Does it mean $40 is purely installation fee?
Ask your ID if any PE endorsement is needed. If there is, ask how much he charge. I've got a contact at $300 for PE. PM me if u need.
For painting works, I've got this Myanmar guy charging $300 to paint my 4room flat. But u have to get your own paint. Sure cheaper than those offered in the market. PM me if u need.
I dun quite understand. But I've got my lightings from lightings.com.sg. Cannot remember their charges but if I'm not mistaken, it's $38 for first point followed by $7 per point. N they deliver n fix at your convenience.
Yup, that's for lighting.com.sg, should be $30 1st point follow by $7 but that's the price for 2 yrs ago, think its more ex. now :D ....delivery fee another charges.
Kitchen
2 nos Toilets
Plumbing Works
Ceiling Works
Carpentry Works
Miscellaneous
total $28,535.00
Overall I find it reasonable,things have been going up, levy,materials,etc...but not our salary... :D , happy renovating. :yamseng:
Edited by jaskel
well this is an extract of the electrical works i was quoted.
seems abit weird that i am charged $40 per lighting point but downlights i have to supply/pay additionally. Is this normal? Or is this perhaps referring to the cost of the electric wire laying within the false ceilling etc
Edited by ricleo
This is normal. 2 ways of doing that for the quotation, 1 include laying of wiring and trunkings with installation of lighting, another is separate laying of wiring/trunkings and installation of lighting fixtures into 2 items. As for what type of lighting fixture, the house owner will need to buy and supply it to the electrician/contractor/ID. :yamseng:
Downlights are provided by customer, i dont think any firm will wanna include downlights inside. Downlights got different brand, different designs, different light bulb or energy savings or long-lasting bulb, etc. All these are cost differently.
Which firm will wanna take the risk to provide downlights? Surely will have conflict.
LIVING/DINING
1 To design & construct (est.L9.5ft) full height shoe cabinet c/ storage cabinet using solid-ply laminate $ 3,040.00
2 To design & construct (est.L8ft) half height TV console using solid-ply laminate $ 1,440.00
3 To design & construct (est.L3.5ft) full height cabinet using solid-ply laminate $ 1,050.00
4 To design & construct (est.L6.5ft) half height study table using solid-ply laminate $ 1,170.00
TOTAL LIVING/DINING $ 6,700.00
MASTER BEDROOM
1 To supply labour to dismantle existing door & door frame $ 200.00
2 To supply labour to make good to damaged area $ 150.00
3 To supply & install veneer door c/w lever handle $ 350.00
4 To supply labour to construct (est.L8.5ft) full height partition wall using adjacent board w/paint finish $ 800.00
5 To design & construct (est.L10.5ft) full height casement wardrobe using solid-ply laminate $ 3,800.00
TOTAL MASTER BEDROOM $ 5,300.00
BEDROOM 2
1 To supply & install veneer door c/w lever handle $ 350.00
TOTAL BEDROOM 2 $ 350.00
BEDROOM 3
2 To supply & install veneer door c/w lever handle $ 350.00
TOTAL BEDROOM 3 $ 550.00
MISCELLANEOUS WORKS
1 To paint whole unit using ICI/NIPPON paint to all walls and piping (unlimited amount of colours) $ 1,700.00
2 To lay cardboard protection for working areas $ 300.00
3 To provide general cleaning for entire unit $ 300.00
4 To clear and discard debris $ 300.00
TOTAL MISCELLANEOUS WORKS $ 2,600.00
PROFESSIONAL SERVICES
1 Design consultation
2 Space Planning
3 3D perspective and detail drawing
4 Material and color proposal
5 Site Management/Project Management
TOTAL PROFESSIONAL SERVICES $ 1,500.00
GRAND TOTAL (excl.GST) $ 17,000.00
GRAND TOTAL (include GST) $ 18,190.00
GRAND TOTAL (include GST) after discount $ 16,500.00
