Jaclyn88
Help! I Cant Find The Right Id
Hi, if you don't mind. I can recommend you my contractor. He is well experienced. Even though I have the knowledge in design. He is more hands on in terms of construction, his quotation is reasonable, and itemized quite detailed. You will see his dedication after engaging this contractor. He will personally look into the renovation process. He even gave me a schedule and really keeping it to the timetable. He was the first person to contact me in 15 mis. After I sent out a request for quotation from all contractors.
Due to my bank standing. Bank loan was reduced. He gladly revised my quotation.
I want you to check this contractor, not only that he became my friend after engaging him. Even though my construction is still on going. He manages his time to follow up with some decisions that he need from me.
PM me if you need his contact.
Can pm me the contact? Thanks.
ID has good design taste and can provide logic idea that WOW any visitors. Contractor has good coordination skill that able to provide architecture detailing that WOW the end-users.
Which one do you choose when you have just gotten a house?.................be very careful on your selection... cause ID is very costly, they will not entertain a 10K job, on the other hand, Contractor will not entertain if the house look proportion.......
Very often, owner mixed up between ID, Salesman, and contractor, but i believe they sure will end up discover who they really work with after job completion, unfortunately not before signing up the contract.
It's always good to do a back ground check direct or indirect about the renovator that you are going to engage with, that goes to the company too. An ID/ Contractor should at lease have 3-5 years of Field experience, and its company should at lease has a HDB licensed....... otherwise it is better to try look around again ;)
Don mind if i can recommend, cause i just visited one of my customer new place for upholstery work. I am pretty impress with the design and finishing plus the passion of that id. Really accompany the customer to my factory just to select few pieces of fabric for 2 pieces of cushion work.
Joey Pear (Dyel pte ltd). 9xxx xxxx. Only recommend is because am really impressed by him
Edited by JuzChris
Contact removed
Kindly PM me with your ID
Guest Tiffany Sum-Yao
My id company is lousy. Suppose to do 1 kitchen and 2 bathrooms within a month and give an allowance to 1.5 months (Till 25 Aug 2013). The id either unable to manage his workers or cant rebothered about it. So up till today, its till an unfinished project with disputes
One of my heater got problem after installation. The master heater was ok and the common heater had problem. My ID text me saying that my heater spoilt. I ask him, are you sure. He replied that after his plumber installed, he asked his electrician to come test the electricity and no issue. So I asked him what am I suppose to do. I asked him whether he can take it down and I bring it to the shop (I didn't buy the heater from his recommended shop as its twice the price there) and then he put it up for me. My ID said that he only put one once, cant take down and put up again. So I had to call my heater company to ask their peeps to come down. Ariston engineer came and was laughing his head off - ah di , your contractor stupid is it, in and out also never put properly. Put opposite. So there waste half a day of freaking leave for me.
My custom made kitchen cabinets, were of worse quality than off the shelves, with the laminate edges jagged and poorly formed. They refused to change it at first and got their carpenter down to touch up a few times. I barred my flat recently so the last two times the carpenter came down, I was present. The first time, there were no visible difference to kitchen cabinets and drawers. Their carpenter went off happily and just walk past me and say finished already before I can say anything.
The 2nd time, the carpenter brought another younger colleague down and was suppose to "change" the laminate, there was another contractor who came to varnish the doors. The varnish contractor was waiting for me whileas the carpenters came slightly late. The carpenters came in for an hour or so, broke for lunch for about 2 hours plus and returned, whileas the door varnish carpenter was an external contractor employed by them, stayed throughout the lunch time to complete his job before going to take his lunch.
The carpenters to my horror, touch up my dark brown cabinets and drawers, with kindof green stuff. So my cabinets and drawers were greenish in colour at the corners. I called my ID to tell him, and I had to wait for 2 plus hours for him to come and view.
Furthermore, their workers walk from my master bedroom toilet to the living room when their boots are covered with cement. So my broken marble flooring had cement stains from the toilet entrance to the living room. Not only stains, but my broken marble flooring was scratched and had holes in it.
Be wary if you take this company IDs. PM me if you want their company and names. 3 big companies but 2 are subsidiaries with one main. My company is one of their subsidiary. So even when people say chose big company sure no problem, its like freaking ****.
can pm your id?
Hi, can I have the contact too? Thanks!!!
Hi, can u pls pm his ID. Thx!
Hi Jaclyn88,
for 4rm BTO flat cost shld be around 20k, but it all depends on the material and also the works to be done.
If you dun mind another view, i can intro my renovator. Good service i would say. Let me know.
Have a smooth sailing reno~
mikey
Hi Mike,
Seem from your posting to a Silver member.
Can I request you to Private message me your contractor contact.
Mine 4rm Resale need major overhaul.
Apologies to the thread starter for hijacking your thread
Can share contact of your contractor,
Please Private message me.
Got to meet up a lot of ID,s for tomorrow till weekend.
Cheers!
