HI All,
Pls kindly help to advise whether the below quote is reasonable. If have any recommendation, pls advise. Really appreciate your help.Thanks
A Living Room Works
1. Design, fabricate and install (L) 4.5ft x 8.5(H) height 'solid plywood' shoe cabinet using laminate materials inclusive of :
ABS Trimming
45* degree handle with ABS Trimming - $1,125.00
2. supply labour and install 8ft x 8.5ft tinted mirror panel with wooden plank backing at dining table wall area - $1,972.00
(just ask our ID to re-quote to half height as full height is too pricey)
3. design, fabricate and install (L)11.5ft x 8.5ft (H) solid plywood TV feature wall laminate materials inclusive of :
ABS trimming - $2,530.00
4 design, fabricate and install 11.5ft solid plywood TV console using laminate materials inclusive of :
ABS trimming
tinted glass drawer head
45* degree handle with ABS Trimming - $2,300.00
B Bedroom Works 3
1 design, fabricate and install (L)7ft x 8.5ft (H) solid plywood top hung cabinet using laminate materials inclusive of :
ABS trimming
45* degree handle with ABS Trimming - $910
2. design, fabricate and install 7ft solid plywood study table with bottom drawers using laminate materials inclusive of :
ABS Trimming
45* degree handle with ABS trimming- $840.00
3.supply labour and materials to install 17.5sqft of 5mm thick tempered colour glass backing between study table and wall hung cabinet - $490.00
C Master bedroom works
1. Design, fabricate and install 11.5ft solid plywood low satee with cushion seat cabinet using laminate materials inclusive of :
ABS Trimming
45* degree handle with ABS trimming - $2,300.00
2. design, fabricate and install (L) 6.5ft x 8.5(H) to ceiling height solid plywood bedhead complete with :
cushion backing as per design
laminated material
45* degree handle with ABS Trimming -$2,350.00
D Common bathroom works
1. design, fabricate and install (L) 3ft x8.5ft (H) solid plywood mirror cabinet using laminate materials inclusive of :
ABS trimming
45* degree handle with ABS trimming - $450.00
E Window and grille works
1. supply labour to install aluminium BA/NA window grille at service yard (3tracks) - $380.00
F Kitchen works
1. supply labour and materials to install fixed panel with fan hole for exhaust fan - $580.00
G Ceiling works
1. supply labour and materials to construct false ceiling **** hall area - $880.00
2. supply labour and materials to construct U shape with down lighting effect- $1,780.00
3. supply labour and materials to construct false ceiling at passage way - $380.00
4. supply labour and materials to construct false ceiling at bedroom 3 - $680.00
5. supply labour and materials to construct false ceiling at bedroom 2 $580.00
6.supply labour and materials to construct false ceiling at master bedroom - $780.00
H whole house ceiling wiring works
1.17 nos lighting point at the living room area - $935.00
2. 4nos lighting point at bedroom 3 - $220.00
3. 4nos lighting point at bedroom 2 - $220.00
4. 4nos lighting point at master room - $220.00
5. 4nos ceiling fan point - $220.00
Total amt : $23,122.00
7% GST : $1,618.54
HI All,
A Living Room Works
ABS Trimming
ABS trimming
B Bedroom Works 3
ABS trimming
ABS Trimming
ABS Trimming
laminated material
ABS trimming
F Kitchen works
G Ceiling works
7% GST : $1,618.54
Can share what company? Many not GST registered, if I were you i will look for those.
Hi All,
I have gotten a few quotations for my renovation works.
Help me check I am overcharged or the price is alright.
1) Kitchen renovation.
a) Masonry
- Cabinet and Fridge bottom
b) Carpentry
- 25ft top & bottom
- 12.5ft quartz tabletop
- 2ft tall cabinet
- 2 tier dish rack
- tempered glass 7ft
- labour for hob, hood and sink installation
- move one electrical point
2) Living Room
- Wall Feature full height L7.5ft
- TV console 7.5ft
3) Windows and Yard
- 4 rooms metal grilles
- Yard sliding window
Total $9,650
Hi All,
a) Masonry
b) Carpentry
- 25ft top & bottom
- 2ft tall cabinet
- 2 tier dish rack
2) Living Room
- TV console 7.5ft
3) Windows and Yard
Total $9,650
i felt yours look pretty reasonable... my frenz has a quote similar to yours but kitchen top is granite.....
