Artrendsupporter
Daikin Aircon - Purchased Through Artrend
Could you share if you have experienced the same ....
Just installed 3 Daikin air con units RKS60, RKS50, RKS25 in november 2013.
Within a month, the RKS50 broke down. We were told that it was due to a bad swing compressor, fan motor dc and printed circuit assemby. Today, barely 2 months after installation a second unit RKS60 broke down. I observed exactly same symptons.
Dont what has happened to Daikin. Thought this is the most reliable ac brand?
My Daikin air-con also got problem in less than 2 years. Installed system 3 with master bed room having 12000BTU and 2 common rooms with 9000btu. After 3 months, thr raddling noise always woke us up in the middle of the night. After 1 year, when 1 of common room aircon is switched on, my masterbed room unit start blowing hot air. Repaired and now flipper broken and now all 3 bedrooms aircon raddling when operation and seems like cannot solve the problem.
Now wanted to change new aircon completely and hunting.
