harky
Can I Use Sand Paper To Smooth An Old Wood?
i had a very old cabinet wood.
i want to remove the lamination and smooth the wood surface.. if dont have the sand machine , i use sand paper can a not?
Sand laminated surface with sand paper? :no:
Don't believe? Try lor.
Spray cleaning liquid but don't ask me what and where to get.
You can remove the lamination if it is peeling off. But usually laminated wood are those plywood, or grain wood. After sanding, are you going to re-laminate? I believe you re-laminate, the side are more difficult to do. But with patience, you can....
Unless the tree which that piece of wood came from is extinct... otherwise, I think what you are trying to do is not worth it at all. Laminate can be peal off but they cannot be peal off perfectly. You will definitely need a sanding machine. No chance with sand paper and arm power.
What if i have a strong arm, hahaha
