Rondell
The Cleaning Of Dirty Tiles And Grouts
I have one question to ask, i always travel for work and when i come home i notice my toilet floor is very dirty
and the grouts black, its seems very difficult to clean them, anyone expereinced this before? If yes what are the solutions to
remedy this?
Any help is appreciated :)
  • Like 8
remedy this?
Remedy - it's time to change floor tiles to darker color with rough surface and with minimum grouts. No white cement please.
Same strategy applies for the kitchen floor tiling.
  • Confused 1
On 20/11/2014 at 2:25 AM, Rondell said:
If yes what are the solutions to remedy this?
From what you describe it seems to be ingrained dirt and hard water stains.
You can use something called HCL89. to clean the tiles
I usually get it from http://hcl89.byethost10.com or  http://hcl89.atwebpages.com
One thing i like about it is that is creates like a protection like on the tiles so that it prevents such hard water stains or dirt from becoming an issue for your tiles
Hope this helps you out :)
Edited by EricCantona
  • Like 8
anyone consider a jetspray ? admittedly, it's a bulky item to store.
but hey, no use of chemicals. And that's a good thing.
May i check with gurus here, what should i use to fill grouts? Toilet floor tiles are grouts are exposing...dun know what to use to refill them especially its for toilet floor...
Thanks in advance for advice.
  • Haha 1
Seems like it, but TS says he travels for work so should probably be months in between usage
Edited by Glenn72
  • Like 9
On 08/09/2015 at 5:18 AM, StyloMylo said:
Jetspray i think uses alot of water, your water bill will skyrocket, not advisable in my opinion
Ya water bill will go through the roof
  • Like 6
