sherwinsm
Extending Ceiling Lamp Cable
Hi guys,
Im currently reusing my existing pendant lamp to place in our balcony em. the balcony has a high ceiling.
I need to extend the cable and extend the support for this.
My lamp loooks similar to this:
Can anyone help how i should go about doing this?
Balcony is false ceiling or concrete?
If concrete, is there an electrical termination point for you to install balcony light?
If false ceiling, do you know if there is a termination point above?
This is just to know if you really need to extend the cable.
there is a power point in the ceiling.
my dilemma is how to extend the short steel pole or extend the chains instead...
if extend the chains only. im afraid it will sway like crazy. if extend the steel pole. i dont know where to get that.
hi,
I think if you remove that metal cap, you would probably see the electric terminator.
Make sure your unit's main power supply is off before you remove it. Better safe than sorry.
I think extending the rod would be tough because you gotta hunt for a new rod and that's not easy. It's easier to run a chain down . That means, the Y connection that your current 2 chains are, will be shifted down.
I wouldn't suggest just running a cable down without a chain and just let that cable bear all the weight. A chain is stronger and can be more flexible during windy situation.
cheers
Teck Chye
