jimmya
Is This Quote Cheap And Reasonable?
On ‎26‎/‎07‎/‎2015 at 2:05 PM, jimmya said:
Do advice.
Construct fridge base - $150
c/w Blum Hinges
c/w Color polygon
- all doors in ABS Trimming
- 1 set of cultery tray
Chemical Washing - $200
Total $22235.
Do advice and help me out.
thanks
Hi Jimmya,
please pm me your id contact.
TIA. :)
I had recently encountered a case where the renovation contractor causes a water pipe to burst and there is water dripping all over. So, advice all not to take it lightly and trust lousy company. I highly recommend Sigmon construction.
hi guys, had pm u. my photos are in thread page 10.just in case u want to see
coz alot of u had ask me about my house reno.
all d best!
On 8/15/2016 at 9:06 AM, dabendan said:
Hi guys, is this quote reasonable ?
eh? thought you posted that you did 9k renovations from a renovation company le?
bro,
do pm me the contact details.
went for quite a few ids, the price is very wide range,.. at least urs is reasonable price.
thanks alot.
