Hi Jimmya,
Im getting my keys in Q1 next year. I would really appreciate if you could PM me your ID contact and company.
Btw, I cant seem to view the photos you uploaded. But I bet its nice reading from the comments.
Thanks in advance! :)
Hi guys,
mind helping me check if this quote is reasonable. is there any additional hidden stuff that they forgot to add in?
1
Application for Renovation Permit
FOC
2
Aplication and Payment for Professional Engineers
By Owner
B          Hacking and Dismantling Works
To supply labour and tools:-
1          Hack existing full-height wall between kitchen and dining room as per plan.
330.00
2   Dispose of debris to ENV designated area.
150.00
C          Wet Works
To supply labour and materials:-
1          Plaster existing wall and ceiling to produce smooth surface for the affected
area (after hacking of wall).
260.00
2
Replace damaged floor/wall tiles for the affected area in living room/kitchen.
380.00
3
Construct cabinet cement base @ 50mm (H) with skirting finish by using
2-in-1 prepacked cement in kitchen as per plan.
1,200.00
4
Construct outlet PVC drainage pipe concealed under the base for kitchen sink.
120.00
5
Overlay 30x30cm heavy duty porcelain floor tiles with W1 and chemical
cement in 2 bathrooms.
1,600.00
D         Plumbing Works
To supply labour only for installing:
1
2 nos. w/c @ $120.
FOC
2
01 no. kitchen sink and tap ($120)
FOC
3
02 nos. bidet spray with extension of stainless steel pipe @ $60.
FOC
G         Carpentry Works
5          d)  install frosted glass drawer head.
e)     install maximum 2 nos. drawer lock.
6          Custom make storage platform with steps @ 3300mm(L) x 3000mm(W)
x 400mm(H) approx. in master room as per design.
5,600.00
7          Custom make low-height storage cabinet with sliding door @ 2800mm(L) x
400mm(W) x 400mm(H) approx. in master room as per design.
1,200.00
H          Work Top
1          Fabricate and install standard range 'Quartz' kitchen work top with single
profile cum backsplash skirting finish in kitchen as per plan.
1,680.00
G         Carpentry Works
To supply labour and material: Material: laminate with internal white PVC finish.
1          Custom make 'L' built-in kitchen cabinet top and bottom @ 4300mm(L)
approx. in kitchen as per design.
3,640.00
2
Custom make 01 set of drawer with PVC cutlery tray.
480.00
3
Custom make built-in storage cabinet above the fridge as per design. ($420)
optional
a)     install solid plywood door with ABS trim edges.
b)     install internal storage shelving.
c)     install soft close hinges.
d)     install 01 no. stainless steel dish drainer.
4          Custom make full-height built-in shoe cabinet with internal storage shelving
cum tic-tac swing door to camouflage household shelter as per design.
1,350.00
5          Custom make full-height built-in, walk-in closet with internal colour PVC
finish @ 3600mm(L) approx. in bedroom 2 as per design.
4,480.00
a)  install internal storage shelving.
b)  install maximum 6 nos. of drawers.
c)  install standard aluminium hanger rod.
Edited by happyman89
Hi There!
You might consider using solid surface as your kitchen cabinet top!
It's longer-lasting and more durable....
If you need more details, please feel free to contact me! brenda.tan@hbp.com.sg
Thank you!
Anyone who has the Name or contact of the ID that jimmya used, appreciate if you pm me. It seems v good.
Edited by Idle
