On 26/07/2015 at 2:05 PM, jimmya said:
Do advice.
Construct fridge base - $150
c/w Blum Hinges
c/w Color polygon
- all doors in ABS Trimming
- 1 set of cultery tray
Chemical Washing - $200
Total $22235.
Do advice and help me out.
thanks
Hi, came across your post. Mind if you share with me ur ID contact please? TIA!
Edited by Dawntie
On 7/26/2015 at 2:05 PM, jimmya said:
Do advice.
c/w Blum Hinges
c/w Color polygon
Total $22235.
thanks
Hi can PM me your ID contact n firm ?
On Sunday, July 26, 2015 at 2:05 PM, jimmya said:
Do advice.
c/w Blum Hinges
c/w Color polygon
Total $22235.
thanks
Hi jimmya, can PM me the contractor details? Thanks thanks! :)
