hi all,
got him to reno my house, nicely done up, not the cheapest nor most expensive prices.
will like to commend well o his work. thanks
On 26 July, 2015 at 2:05 PM, jimmya said:
Do advice.
Construct fridge base - $150
c/w Blum Hinges
c/w Color polygon
- all doors in ABS Trimming
- 1 set of cultery tray
Chemical Washing - $200
Total $22235.
Do advice and help me out.
thanks
Hi, Can share contact number and person in charge on above contractor. Thank u so much. Can email me at bernlin70@gmail.com.
On 07/01/2017 at 8:25 PM, davetan said:
hi all,
Hi davetan, you're using the same contractor jimmya used? if so, can PM me the details? Thanks!
hi @jimmya can you pm me your ID contact please?
Thank you!
May I know if there are any hidden costs that were not included in the quote given to you?
Were you asked to top-up other than those you requested/changed?
