Upgrade Supply and lay HDF laminated flooring to Supply and lay 5mm thick click system vinyl flooring c/w skirting at all bedroom
660.00$
Masonry Works
Supply materials and labour to lay selected craft stone on constructed faux wall **** room
$ 1,430.00
carpentry Works
Living / Dining
Design and fabricate L2400mm, full ht faux wall using reinforced gypsum board with paint finish $ 780.00
Design and fabricate L2400mm, suspended Tv console finished with selected laminate as proposed by designer$ 1,040.00
Design and fabricate L1200mm, half ht shoe cabinet finished with selected laminate as proposed by designer $ 560.00
Design and fabricate divider on half ht shoe cabinet finished with selected laminate as proposed by designer$ 440.00
Design and fabricate L1800mm, H1050mm mirror frame finished with selected laminate as prposed by designer $ 760.00
Design and fabricate L650mm, full ht altar c/w tempered glas backing finished with selected laminate as proposed by designer
$ 1,380.00
Kitchen
4.7 Additional Design and fabricate L900mm top and bottom kitchen cabinet finished with selected laminate as approved by designer
$ 360.00
Service Yard
4.8 Design and fabricate L650mm X 2 wall ledge shelf finished with selected laminate as proposed by designer
$ 180.00
Master Bedroom
4.9 Design and fabricate L2100mm, full ht sliding door wardrobe finished with selected laminate as proposed by designer
$ 1,680.00
4 Carpentry Works Cont. Bedroom 2
4.10 Design and fabricate L1550mm, full ht sliding door wardrobe finished with selected laminate as proposed by designer
$ 1,200.00
4.11 Design and fabricate L950mm, suspended study table c/w drawer and lockset finished with selected laminate as proposed by designer
$ 390.00
4.12 Design and fabricate L950mm, top tiered cabinet finished with selected laminate as proposed by designer
$ 450.00
Bedroom 3
4.13 Design and fabricate L1550mm, full ht sliding door wardrobe finished with selected laminate as proposed by designer
$ 1,200.00
4.14 Design and fabricate L2400mm, suspended study table c/w drawer and lockset finished with selected laminate as proposed by designer
$ 1,040.00
4.15 Design and fabricate L750mm, top tiered cabinet finished with selected laminate as proposed by designer
$ 375.00
Master Bathroom
4.16 Design and fabricate L600mm, suspended vanity cabinet finished with selected laminate as proposed by designer
$ 200.00
4.17 Supply and install L600mm selected quartz top at vanity cabinet $ 240.00
4.18 Design and fabricate L1200mm, mirror cabinet with open shelf finished with selected laminate as proposed by designer
$ 600.00
Common Bathroom
4.19 Design and fabricate L750mm, suspended vanity cabinet finished with selected laminate as proposed by designer
$ 250.00
4.20 Supply and install L750mm selected quartz top at vanity cabinet $ 300.00
4.21 Design and fabricate L750mm, mirror cabinet with open shelf finished with selected laminate as proposed by designer
$ 375.00
Additional charges may incur base on complexity of design and material used All Carpentry works use Solid Ply wood unless otherwise specified
$ 13,800.00
5 Glass Works
5.1 Supply and install L1500mm, H1050mm clear mirror on wall at dining area $ 280.00
5.2 Supply and install 10mm thk tempered clear glass fixed panel shower screen with matching casement door at master bathroom
$ 390.00
5.3 Supply and install 10mm thk tempered clear glass L shape sliding door shower screen at common bathroom
$ 690.00
$ 1,360.00
6 Doors / Windows Kitchen
6.1 Supply and install selected swing and slide (2 piece glass panel ) door at entrance $ 350.00 Service Yard
6.2 Supply and instal L2400mm alum (NA/BA) HDB approved design sliding window $ 480.00 Master Bedroom
6.3 Supply and install solid verneer door c/w lockset, stopper and varnish $ 450.00 Bedroom 2
6.4 Supply and install solid verneer door c/w lockset, stopper and varnish $ 450.00 Bedroom 3
6.5 Supply and install solid verneer door c/w lockset, stopper and varnish $ 450.00 Master Bathroom
6.6 Supply and install 10mm thk, tempered glass (frosted) casement door at entrance $ 390.00 Common Bathroom
6.7 Supply and install selected swing and slide (2 piece acrylic panel ) door at entrance $ 280.00
$ 2,850.00
7 Plumbing Works
Master Bathroom
7.1 Supply labour to dismantle existing wash basin $ 80.00
7.2 Supply materials and labour to install new inlet, outlet pipe on vanity $ 100.00
7.3 Supply materials and labour to install wash basin and tap $ 80.00 Common Bathroom
7.4 Supply labour to dismantle existing wash basin $ 80.00
7.5 Supply materials and labour to install new inlet, outlet pipe on vanity $ 100.00
7.6 Supply materials and labour to install wash basin and tap $ 80.00
Additional Plumbing Works price list:
Supply labour and materials to install storage heater / 2 x instant heater @ $150 TBA
Supply labour and materials to install rain shower @ $130 TBA
Supply labour and materials to install bidet spray @ $45 TBA
Supply labour and materials to install bathroom accessories @ $70 TBA
$ 520.00
8 Electrical Works
8.1 Supply materials and labour to relocate existing 2X13A power point 1 $ 70.00
8.2 Supply materials and labour to relocate existing SCV point 1 $ 110.00
8.3 Supply materials and labour to relocate existing Cat 6 data point 1 $ 130.00
8.4 Supply materials and labour to install ceiling fan 4 $ 300.00
Additional Electrical Works price list:
To supply & install ceiling/down light point @ $38 TBA
To supply & install 1x13Amp power sockets @ $60 TBA
To supply & install 2x13Amp power sockets @ $70 TBA
To supply & install SCV point @ $110 TBA
To supply & install Telephone point @ $70 TBA
To supply & install Cat 6 data point @ $130 TBA
To supply and install switch (single gang) @ $45 TBA
To supply and install switch (multiple gang) @ $65 TBA
Labour to install ceiling fan @ $75 TBA
Labour to install ceiling/down light @ $10 TBA
Labour to install hanging light / chandeliar @ $80 TBA
Labour to install cove light @ $15 TBA
To supply & install air-con point @ $100 TBA
To supply & install heater point @ $110 TBA
To supply & install DB box @ $380 TBA
To supply & install hood / Oven point@$80 TBA
$ 70.00
Optional Works
Supply and overlay selected non-slip homogeneous floor tiles at master bathroom
44.5sqf $ 280.00
Supply and overlay selected non-slip homogeneous floor tiles at common bathroom
44.5sqf $ 280.00
Supply and overlay selected ceramic/homogeneous wall tiles at master bathroom
220sqf $ 1,320.00
Supply and overlay selected ceramic/homogeneous wall tiles at common bathroom
220sqf $ 1,320.00
Recommend you to go direct to renovation contractor, will save at least 10-20%. ID also will sub contract or the actual work to the Contractor and earn in between. Myself engaged a renovation contractor for my 4rm bto and was greatly satisfied with their services.
Hi James
Can you share your contractor contacts?
Possible to share your quotation for my reference?
Thanks bro.
I don't think is good to share the official quote here, but I will list down the items I do.
Kitchen Cabinets up down both sides with marble top
False ceiling for the whole living room and common areas
3 rooms fully cabinets with study desk and TV features wall in masterbed room
Living room TV features wall will cabinets
Entrance partition divided in between living room and main door.
All lighting and electrical works included
Full house painting and replacing the skirting to tiles
Both toilet shower screen and cabinets.
Total only $25k
Hi James,
please share the contact. Thanks!
Total only $25k
