rapala1982
4Rm Parkedge with Ultimate Reno Newbie Guide
3 hours ago, cutiepetlover said:
Rapala can PM me your id contact please? Thanks!
3 hours ago, jasonjason said:
Hi can pm
both Pmed..jason can you check again i pm quite a while back..good luck
Hi do you mind to share your ID and other suppliers' contacts and all your Taobao links especially the tap? Many thanks!
Edited by Mannequin
On 8/26/2016 at 4:31 PM, srkf16 said:
Hi there! Mind sharing your ID's contact please? thank you!
PMed
On 8/27/2016 at 1:04 PM, noddy said:
Hi, could you PM me your ID contact and quote pls? Thanks!
PMed
On 9/11/2016 at 3:24 AM, adelante said:
Hi! Mind sharing with me your ID contact and quote?? Thanks very much!
PMed, my quote is around 15000..it all depends on what is your requirements. pretty much most ids are charging roughly same prices unless those high end company. most important is rapport..cheers.
PMed, pm if you need have other request.
Cheers and good luck everyone.
On 1/10/2017 at 5:27 PM, Deyna said:
Hello please share your ID contact. Thanks in advance!
done. good luck.
On 1/17/2017 at 6:33 PM, pandacel said:
Dunno why I can't see the pictures :(
Do you mind sharing your ID contact and quote? Much thanks!
done. good luck.
On 1/19/2017 at 3:42 PM, hoWL said:
I cant see the pictures too but 15k is about my budget as well. Can you msg me your contact and quote?
done. good luck.
6 hours ago, project267 said:
Hi interested to know your ID info and contact as wel, do pm me. Thank you!
done. good luck.
