elastic25 0 Report post Posted May 14, 2016 Features: Cement added with K 21 : SBR LATEX will have: Strengthens cement Improved bonding strength by 2 to 3 times to 30.57 kg/cm2 Especially good for bonding homogeneous tiles, granites and marble tiles, and to prevent staining Increased flexural and compressive strength by 40% to 100% Compressive strength to 570.00 Kg/cm2 Flexural strength to 127.41 kg/cm2 (ASTM C 39) Quicken cement setting time Reduced surface cracking and dusting, forming a very tight seal Good for wall plaster, wet area and swimming pool waterproofing 10 to 20 times more resistant to oil, salt water, chloride, acid and vapour penetration. A feature particularly important in steel reinforced concrete structure. Improved plasticity and flow (ASTM C 124-71), easier to work with, reduces porosity Packing : 4 kg Share this post Link to post Share on other sites
