kelvintzy
parquet floor maintenance
hi bros and sis! anyone has any idea how often we should polish our parquet floors and any maintenance tips for parquet flooring? TQ in advance!
Kelvin, polishing frequency is really dependent on how much traffic that space is getting. Some rooms see heavier usage so we do so once in 2-3 years. Especially those areas that are nearer to bathroom cos of moisture.
You can try going to this link for some advice! Parquet floor polishing maintenance tips
My 1 year old parquet floor is filled with scratches. I am not sure if it is the quality of the parquet used or just rough usage.
On 26/12/2016 at 7:03 AM, bepgof said:
Watch out, the wood shrinks and twist when temperature/moisture varies....
Never knew this as i always thought only those unvarnished woods will shrink
  • Like 6
I maintain and clean mine by using this particular cleaner called bona. Sorry for the very late reply. Just joined this forum today =)
On 7/12/2017 at 7:16 PM, fastlocalgaragedoor said:
avoid moisture
Problem is moisture will always be there and moisture is an issue that is very hard to avoid
Alot of wood materials shrink because the varnish wears out after a while, so if you go for wood make sure its treated wood so the shrinkage is very minute
