links to watch more videos
https://www.facebook.com/sg.better.home
https://www.youtube.com/channel/UCU_nfpChZ7JjycgXVhR_qoQ
Procedure to build ducting for hood:
- Provide us with your floorplan, We will do all necessary designs and plan duct run
- Submission to HDB with all necessary details of filtration and type of hoods use, if require by owners.
For the responsibility and gracious sake to our neighbours, we need to ensure that sufficient filtration must be use to trap most of the grease and to bring down the smell of expelled cooking fume to a desirable level.
whatsapp: 91153853 keith
5a87b9ea95254_kitchenexhaustsystem1smallsize.gif.7e036a5f6d5a515b499e0e4dc559bcaf.gif  5a87ba1d4ed8b_kitchenexhaustsystem2smallsize.gif.96a21b6772d84066d59a72181cfec0d0.gif  5a87ba271f650_DSC_016701.gif.4bf0a2abba4591ef778241babe623f92.gif  IMG_20180217_125058.gif.a97114f603c5a4206db1e9fe90ae9637.gif
We had send to HDB various lab tested grease level reports of the filtered cooking fume being discharged was at very low level after being filtered, through our experiments. (refer to the bottom of page)
 We had also send to HDB health reports that inhaling recirculated cooking fume could lead to serious health problem like lung cancer ETC.
                         Completion of above project
IMG-20190703-WA0015.thumb.jpg.ab2b71c3b4345d1abf9824f0aba435ab.jpg  IMG20190611122125.jpg.f40bf33843310ebccc36f698c17d207b.jpg  jhwxjwhxwjh.jpg.442a1bb1040172c6f6054c2cb10638f3.jpg  IMG-20190703-WA0014.thumb.jpg.e3b29e79d87b40e4afb85008bb38965a.jpg
BTO projects
ccgchgchgvhgvhgvhvv.jpg.174b83e0cc9030f51663039179410856.jpgIMG-20180814-WA0002.jpg.b3168d3e3b26e882c0c30a98a2fa84f3.jpgInkedIMG_20180913_171220_LI.jpg.1145cfe94f27766b4b7438ccadb9bba2.jpg
BTO projects
jhervfjhfhjn.jpg.3e0edada0d39789089db6d25a0b68d93.jpgIMG-20190118-WA0016.jpg.67e1b83fdde52c69ea02c15ac8d50d5f.jpg
kjbkjaiuashcui8.jpg.08155828bff980c5f71c64484c3aad35.jpgjhvjhcjhb55.jpg.41820b9e31d85470f2460d04537e7c1d.jpg
Resale HDB Project
hqczhqczhqccvz222.jpg.0206eda70f2c6af022d77b3aee7fdba4.jpghqvgjqvvq333.jpg.6fc43ebb5fb918cd780ec93853df914f.jpg
Resale HDB Project
1331169775_kc004.jpg.fa738bf86a1f7581df423452bc840257.jpg843768953_kc001.jpg.8a827ed2acf695fa321710c0c173368e.jpg
92530298_kc002.jpg.db4519f3326e1f458607f10b8250c59e.jpgIMG20190412133338.jpg.0be937b0f4f4cff19e2512713db2900a.jpg
Condo Project
hvxwhdbxjb6.jpg.43da4f56a65667e4b4f32d995cea4b4e.jpg     hgjwvcjeckjec0.jpg.21fc98301faeae5c1e39739d5ca41e27.jpg
kjwdbgxh55.jpg.cf4b1ee63c8c911fd84d10421cb7e570.jpg     jhsbjlhsbcbcjdhwbc777.jpg.c6f8b451c4d6a0e07c2b7a0327fcb3f5.jpg
Condo Project
     hqxqwxhq111.jpg.11ce4681390cb3dec7655aec0ede9700.jpg     hevdxedvxedv222.jpg.d4d95474cfcc0eaba7ad591ec2cadc2b.jpg
 cjhwcjwcjwhcwjhc333.jpg.c52f92a93bd5119a0d04676d3490e7b0.jpg      44jhvwdcdwci.jpg.01fecafc9440c604fbb4d25cba5e6e32.jpg
Landed Houses Project
IMG_20180905_134650.jpg.078f2600fe8d233659725cc8724b055d.jpg  IMG_20180717_123450.jpg.bb0df68d1847931b99eab55a54c902b9.jpg  IMG_20180717_143550.jpg.153487de63be6a92d457505aa1336920.jpg  IMG_20180905_133232.jpg.e8dde6df3c3c9e8f940d70def73a4cb4.jpg
IMG20190626164425.jpg.36434d10c75820cbcd5d72a8bf22d436.jpg  IMG20190626120205.jpg.1e503ba72d074d049436f0e94be7457b.jpg  IMG20190626164412.jpg.a4cf29f03f4075329a08bd272b35a6be.jpg  IMG20190626122521.jpg.cdf6d26e4fe0ee78f2a896051997671f.jpg
We are builder of Special imported PVC airduct that caters to Singapore housing needs from flats to condominiums, we think that a good ventilation is so important and worth investing, this is because living in a flat, the air quality is mostly stuffy and cooking without a good ventilation is very unhealthy ESPECIALLY when using a recirculating hood, this is supported by various scientific studies and findings.
In various countries as we had seen, flats or most houses are build with a VENTILATION duct that u can connect your hood output air flow to them, that lead to a public underground airflow “tunnel” much like our sewage system tunnels or roof tops ETC.
Many or most Singapore family cook without a good ventilation system, at the most you can buy a good fancy recirculation hood it looks like that.
If u study the picture carefully, there are 2 filters for this kind of hood namely the grease filter and the charcoal filter(I am quite sure 98% of u don’t know about the charcoal filter). Having said that, the question is how efficient is this kind of hood? Well, if you are a flat owner, with this fancy hood and you cook before, I am quite sure you knew the answer. Its useless, Why? Yes although the 2 filters did their job, filtering more than 95% of the grease from the cooking fume it “inhale”(This is supported by our experiment with Lab certified results, attached are pictures of experiment and the lab report). And the charcoal filter remove most of the odour in the warm cooking air that passes though it.
Allow me to pose a few questions Firstly, can the hood suck the warm air and cool it down, no! common sense tells! The warm air from the gas stove keeps on recirculating in your kitchen, meaning it will get warmer and warmer and carbon dioxide will get higher and higher, is this good for your lungs?
Secondly, if you are using gas stove who knows what is inside the combusted gas that will also recirculate in your kitchen? Imagine lighting a gas stove in your bedroom when you sleep, I am not sure if you are going to get up from your sleep or not.
Thirdly, and MOST importantly cooking fume contains CARCINOGEN (a substance capable of causing cancer in living tissue) Various reports and studies have strongly indicated inhaling cooking fume might lead to lung cancer and other respiratory diseases, Please read this link: http://www.tnp.sg/news/singapore/cancer-cooking-wok
Therefore by using special ducting to re-route the output Filtered air out of your kitchen is DEFINITELY necessary!
our experiment on the grease level at the output
lab report
Edited by tisankongjian
Can someone comment is this ventilation approved? or need HDB approval and how to get it? The idea looks clever and can remove most of the odour during cooking.
