Ling0
Idea to Make Use of Structure Wall in Living Room?
54 minutes ago, AndreaLee said:
What do you mean by structure wall from here ya ?
He meant the structural wall that is sticking out like a sore thumb in the living room. See measurement 5800 from the entrance.
For TS, I believe there is a structural beam too at the same spot, running across your living and dropping down 40cm from the ceiling, yes?
I would have use it as a pivotal TV wall, allowing the TV to swing 180deg between living and dining. If you would send me a copy of your floor plan I will draw and show you.
I would probably customize some storage settee with cushioned top. Then put the dining table vertically, so the settee can act as a dining chair for extra pax during parties too! :)
Why don't you partition along the structural pillar to create a new bedroom?
