George Yeo
Rebuilding my Semi D
On ‎10‎/‎1‎/‎2019 at 8:37 AM, George Yeo said:
15.m including cabinetry
1.5 million? What size is the land and what size is the built up for your project?
land 3150, layout is ground floor. mezzanine, second flr and attic level. built up slightly more than 5000 sqft
33 minutes ago, Keithsnow said:
hi george, can you share if your total cost of 1.5m include gst?
how is your experience with your main con?
Also can you pm me your contractor name?
Yes GST included. So far I'm very happy with my main con. Actually he is also my architect, he runs both companies.
2 hours ago, George Yeo said:
Internal walls plastering begins..
Is this your kitchen? Cos the light switch seems to be much higher than the 1.2m requirement
20 minutes ago, George Yeo said:
it is 1 of the 2 common rooms @1.3m
I may be wrong but my understanding is that BCA mandates that all light switches and sockets must be between 450mm and 1200mm from the finished floor level with the exception for kitchens. you may want to confirm with your QP on this requirement.
Initially the height was 1m but I don't like too low and asked for 1.3m, and they mentioned no problem after checking.
Thanks for highlighting it to me.
