ben9823
If it is bad fengshui, what remedies?
hi,
Is any of the following bad fengshui (fs)? What remedy can I take? Appreciated.
1. ?
Is it bad fs if there is a beam right above main door?
If its bad, what is the remedy?
2. ?
Is it bad fs if there are concealed shoes cabinet at both side?
3. ?
Is it bad fs if the mirror (m) faces concealed shoe cabinet?
4. ?
Is it bad fs if the bedroom door faces partial
open concept kitchen though there will be dining table in between the bedroom and the open concept kitchen?
If its bad, what is the remedy if the bedroom door faces partial open concept kitchen?
5. ?
Is it bad fs if the bedroom door faces partial common toilet?
If its bad, what is the remedy if the bedroom door faces partial common toilet?
6. ?
Is it bad fs if the master bedroom door is open to the left?
If its bad, what is the remedy if the master bedroom door is open to the left?
7. ?
Is it bad fs if the master bedroom door is near to the master bedroom Toilet door?
If its bad, what is the remedy if the master bedroom door that is near to the master bedroom Toilet door?
8. ?
Is it bad fs if the master bedroom door opens rested on the wall of two toilets?
If its bad, what is the remedy if the master bedroom door opens rested on the wall of two toilets?
9. ?
Is it bad fs if the air con is installed above the master bedroom Toilet door?
If its bad, what is the remedy if the air con is installed above the master bedroom Toilet door?
10. ?
Is it bad fs if the electronic appliances (small fridge) faces the bed head though a mounted small ledge in between the bed and the electronic appliances?
If its bad, what is the remedy if electronic appliances (small fridge) faces the bed head?
Appreciated.
Edited by ben9823
On 11/11/2019 at 5:59 PM, ben9823 said:
hi,
1. ?
Is it bad fs if there is a beam right above main door? Yes
If its bad, what is the remedy? Cover up the beam if possible else you can paste 5 emperor coin on the beam above the door from left to right
2. ?
Is it bad fs if there are concealed shoes cabinet at both side? Be side the main door? since is concealed, no issues. But tried not to stack your shoes above shoulder level.
3. ?
Is it bad fs if the mirror (m) faces concealed shoe cabinet? No
4. ?
open concept kitchen though there will be dining table in between the bedroom and the open concept kitchen? Depends if you are able to see those electric appliances or stove from your bed or when you stepping out of the bedroom.
If its bad, what is the remedy if the bedroom door faces partial open concept kitchen? Best is you can cover up the kitchen since kitchen is a wealth area, open concept tense to make one have higher expenses. Else shift the electric appliances out of sight from your bedroom if still not possible hang faceted crystal ball on the top of your door
5. ?
Is it bad fs if the bedroom door faces partial common toilet? Yes
If its bad, what is the remedy if the bedroom door faces partial common toilet? Hang door curtain to longer than knee length on the toilet door and ensure door is close at all times
6. ?
Is it bad fs if the master bedroom door is open to the left? No.
7. ?
Is it bad fs if the master bedroom door is near to the master bedroom Toilet door? not facing  then should be alright
8. ?
Is it bad fs if the master bedroom door opens rested on the wall of two toilets? Dont quite understand the question, but the door rest on where is no issue
9. ?
Is it bad fs if the air con is installed above the master bedroom Toilet door? No, as long as not above sofa, normal room door, kitchen door, main door or bed
10. ?
Is it bad fs if the electronic appliances (small fridge) faces the bed head though a mounted small ledge in beteern the bed and the electronic appliances? when you sleep, do you face the small fridge? when sleeping facing electronic appliances might affect sleep quality
If its bad, what is the remedy if electronic appliances (small fridge) faces the bed head? shift the fridge if you feel that it affect your sleep quality
Appreciated.
hi,
1. ?
Been sleeping under beams and concrete ceiling with enforced steel embedded for donkey years. What 'bad' can these bring? Better than sleeping/staying with open sky, right? Better to sleep 'under a roof' right?
2. ?
Shoe cabinet best to be open-type with well ventilated environment. Keep 'salted fish' in the refrigerator is a FS issue?
3. ?
Mirrors shall be placed at strategic locations for its intended functions therefore maximise the effect. Can see mirror-conceal shoe cabinet relationship, unless the shoe wearers constantly need that mirror to see something that he/she can see directly.
4. ?
To each his preference. No good nor bad. Only like and dislike.
5. ?
Ditto.
6. ?
Not specific question, I assume you refer to 'left-swing' door. This has to do with 'flow' and whether you are right-handed or left-handed. Right-handed tends to find 'right swing' door more convenient. Image you use left hand to open a 'right swing door' and right hand to open a 'left swing door'. If a house come with many inconvenient 'flows' or structures, do you regard these as good FS ?
We change environment to suit our 'tastes', 'conveniences' or whatever you may term. When environment is at upper hand, we need to 'blend in' for co-existence.
7. ?
Image this: a guess at your home while you are using toilet with MDR door open and happen he can view into the MBR. It is a privacy than FS issue.
8. ?
I'm perfectly ok, as long as not obstructing 'my way'.
9. ?
Concern should be the best location that the fan coil could send the cool air to the right space.
10. ?
No fridge at 'bed ROOM'!  Otherwise very likely will make you lazy and fat!
Appreciated.
On 1/10/2020 at 10:18 AM, CoralHC said:
hi CoralHC,
Thank you very much for your advice on my doubts on the remedies for bad fengshui.
I have enclosed images on my concerns for:
: door open resting on the wall shared by the toilets
the distance between the master bedroom entry/ door & the master bedroom toilet entry/ door
