sleepsherpa
CBD vs. Melatonin – Which is a Better Alternative
Sleep disorders have been on the rise since the past decade or so. It is hard to find people who experience healthy sleep every night or don’t resort to a sleep aid. Because sleep is vital to mental and physical health, the growing incidence of sleep disorders around the world is concerning. Sleep disorders are more common in the US than any other country; the reason why scientists and sleep experts are always trying to find out the causes behind it and possible solutions.
If you are one of those people who has failed to get a good night’s sleep in a long time, you are acutely aware of how sleep disorders can strip your life of joy and peace. When you are sleep deprived sleep deprived, everything becomes harder than usual. You lose your appetite, you are unmotivated to work out, your social and personal commitments suffer, and your productivity at work keeps dropping. In fact, the American economy suffers a loss of millions of dollars every year simply because of workers not getting enough sleep.
Don’t be surprised, because sleep disorders have far-reaching consequences. Sleep deficiency causes daytime sleepiness and drowsiness, causing accidents and injuries. Drowsy driving is one dangerous consequence of sleep deficiency and daytime sleepiness. It is as dangerous as driving under the influence of alcohol.
Of course, no person can go without sleep for a long time, and they all reach for some kind of sleep aid at some point. However, the recent FDA warning about conventional sleep medications has led people to look for natural solutions to sleep disorders.
Dangers of Sleep Medication
A large number of people depend on sleep medications for a good night’s rest. Older people have usually prescribed sleep medicines because they are unable to get proper sleep any longer. However, even though in the beginning the medications work as intended, they are harmful in the long run because the user starts to get dependent on them. Most sleeping pill users are unable to sleep again without taking the medication, and the dependence only keeps growing. Most doctors do not hesitate to increase the dosage, but this only adds to the danger.
The FDA has recently called out certain sleep medications for being dangerous and causing injuries and accidents. However, even without the FDA warning, most people have always known about the side effects of conventional sleep medications. They are quick to work, but the chemicals in them are harmful to health and often make sleep disorder worse. Increasing the dosage of the medicine only leads to sleeping pill abuse, some of the most common symptoms of which are:
  • Dry mouth
  • Dizziness
  • Difficulty with coordination and focus
  • Excessive daytime sleepiness
  • Foggy memory
  • Nightmares
  • Itching and swelling
  • Lightheadedness
  • Chest pain
  • Blurred vision or other vision changes
  • Difficulty breathing or swallowing
  • Hives
  • Hoarseness of the throat
  • Palpitations
If sleep medications are continued for a long time, it can lead to other health complications and even death. These fears are not unwarranted because there are a large number of people suffering from the side effects of sleeping pills. Sleeping pills being available over the counter have also contributed to their overuse.
All these fears surrounding sleeping pills have led people to look for natural alternatives. At the moment, there are two natural sleep solutions, one of them proven and the other debatable. They are melatonin and cannabidiol.
Melatonin Supplements for Sleep
Melatonin is the sleep hormone produced by the brain in response to the dark. When the sun begins to set, the body clock tells the brain it’s time to produce melatonin, the hormone that helps us relax, makes us feel drowsy and ultimately gets us to sleep. Melatonin is hindered by bright lights and triggered by darkness. That is the reason why sleeping in a dark room is the healthiest.
Imbalances in the production of melatonin are often responsible for sleep disorders. If shunning bright lights don’t work, then a possible remedy is melatonin supplement. This is a natural sleep remedy that has recently started to be administered to insomnia patients. The reason why melatonin supplement has become so popular is that it is not known to have any side effect for it simply replicates the natural melatonin produced by the brain. The melatonin supplement remedies any imbalance and helps the hormone function normally to bring about healthy sleep.
So far melatonin supplements have not been found to cause any adverse side effect. Because this hormone is already produced by the body, melatonin supplements simply aim to correct any shortage or imbalance of the hormone. However, because melatonin supplements tend to work very quickly, the dosage must be appropriate and timed right. Otherwise, the person can feel drowsy well into the next morning.
CBD Oil as Sleep Aid
Another popular sleep solution that is still controversial to some extent is cannabidiol. Also called CBD, this is a natural extract of the hemp plant, and has been hailed to be highly beneficial for a lot of health issues. One of the most popular uses of CBD is in treating insomnia and other sleep disorders. Although the exact connection between CBD and sleep is not yet known sleep experts believe that CBD helps induce sleep by reducing anxiety and stress. If you have stress and anxiety related issues that prevent you from falling or staying asleep at night, CBD can be used as a natural alternative to conventional sleep medications.
However, if your sleep issues are caused by other health problems or hormonal imbalances, then CBD will not be effective. CBD is also highly controversial and not easily available everywhere. Unlike melatonin, CBD has not been proven to be beneficial for sleep disorders and should be consumed only after a consultation with a healthcare practitioner.
Before resorting to a sleep aid, it is recommended that you try making lifestyle changes to deal with sleep disorders. If all else fails, talk to your doctor to adopt the safest possible way to induce sleep and reduce sleep deprivation.
Melatonin for sleep, like CBD, needs more research to unmask its benefits and harms. Because we secrete melatonin naturally as our bodies prepare for bed, It has already proven that CBD oils are used as a medicine in cases like insomnia, acnee, depression, or anxiety. So, in case of insomnia, CBD oils are helping our body, to secrete melatonine, and that is why CBD oils can help us in case of insomnia. Anyway, there are few studies on that topic, and scientists are only trying to understand why CBD helps in melatonine secretion. You can find more on https://urbanaroma.com/how-to-find-weed-in-dc/.
It is absolutely true that today cannabis occupies a leading position in marketing and in the entire world market because it is effective enough to fight many diseases and disorders. I found it last year https://piff.ca which offered a good and high-quality product that allows you to enjoy your favorite smoke every day, thanks to the legalization of this plant in my state. God save America! This company helped me understand how influential marijuana will soon be around the world and those who were engaged in growing this plant earlier will become billionaires in the future
Both are good but I use only cannabis. I feel the effects quicker hehe. But speaking seriously melatonin is a good supplement. Everything depends on how you feel. I'm not sure what happens when you use them both, have to try it lol. I use CBD oil every morning and I sleep very well I pass over stressed situations and I don't have headaches. Recently one of my friends shared this https://www.healthcanal.com/coupon/cbdfx site with coupon on CBD products. There I read how to use the coupon and bought the oil that I needed. So if you want you can use it too.
