sleepsherpa 0 Report post Posted May 14, 2020 Maybe it’s because I live in the city of lakes which is also located in the land of 10,000 lakes that drew me to the idea of Float Therapy. Float Therapy is a rebranded term for what used to be called isolation therapy or sensory deprivation therapy. It is a practice where you float in a sort of large bathtub that is filled with salt water. Float therapy is a form of mediation. I did my first float session at the Float Foundation in Minneapolis which coincidentally is on the other side of Lake Harriet from my house. I found a Groupon deal for a float session and thought I would give it a try. A 90 minute float session costs $69 while a 60 minute costs 61.99. After purchasing you can book a time via their online calendar on their website. My go to method of relaxation and meditation is the Sol Tec Lounge in my house which is sort of the opposite of the sensory deprivation method where layered music is played along with vibrations to keep you present and avoid distracting thoughts. What are the benefits of float therapy? Here’s a roundup of some symptoms that float therapy claims to alleviate: Stress relief Muscular pain Rheumatism Chronic pain Fatigue Fertility High blood pressure Migraine headache Jet lag Anxiety Insomnia Back pain Depression Pre-menstrual tension Post-natal depression Float therapy also promotes the following: Problem solving Creativity Increase energy Increased feelings of well being The float tank is sound proof or as sound proof as can be, and the temperature of the water is skin temperature so that you aren’t too hot or too cold. The epsom salt allows you to float effortlessly. If you haven’t floated like this before, it is an experience worth having. Here’s a picture of the float room that I used. Behind me is a private shower as well to use before and after using the float tank. I didn’t feel clausterphobic in the float room because the ceiling was high enough at my head. It slopes lower towards my feet but I didn’t find that to be a problem. I booked an hour and a half float session becuase with meditation it takes a while for me to properly relax and I wanted to make sure that I had adequate time to adjust given the new environment. These rooms have a button where you can have a soft light on or push it again for total darkness. I played around with both but ultimately found the darkness to be preferable and less distracting. This float chamber also has a neck support which you can use to help stabilize your head. I don’t think it’s necessary but I ended up using it for most of my session to fell a little more secure and to ensure water didn’t get in my ears. Inside the chamber there is also a dial which can be used to play quiet, relaxing music. I tried that out for a bit and found it enjoyable since it was so faint it wasn’t really distracting. It took me about 20 minutes to fully relaxing during my session. I think that’s because I was just enjoying the experience of floating and total relaxation. For an hour and a half session, this went faster than I expected. There’s no need to worry about over staying your welcome either. The light outside the chamber will turn on to alert you that your session is over. After your session you can rinse off with a shower with soap and shampoo included: I really enjoyed my float therapy session. Since I did it in early March in Minnesota, it was kind of a hassle to get undressed, shower then get dressed again and go off into the cold. However, the warm float tank really took the chill off and took me away from the winter doldrums. While I found the float therapy session to be relaxing, I didn’t have as productive a meditation session as I normally have in my Sol Tec Lounge. It could be that I am used to my form of meditation over this one. Using the Lounge in my house is much more convenient as well. I highly recommend trying float therapy. I think many people will benefit from just being able to tune out the world and all its distractions for an hour. While I didn’t fall asleep during float therapy, I slept very well the night I did my session. Share this post Link to post Share on other sites
Sonilor 1 Report post Posted August 10, 2022 Can this therapy be used to cure some spinal diseases in dogs? Share this post Link to post Share on other sites
Brandcalfe 1 Report post Posted August 10, 2022 (edited) Unfortunately, I don’t live in a place with many lakes, and I cannot even swim. I almost drowned when I was a kid. Therefore I have some other traumatic experiences that I cannot overcome. So, this type of therapy is not for me. But there is the thing that can and does help me – my emotional support animal. Most people think it does not work this way, but I disagree and affirm that my dog is the living thing that saved me from taking my life. Caring about it makes me wake up in the morning and go to work. The only thing I need money for is some food for her and me. These are the most important things. I even have all the necessary ESA documents and certificates in case I need to prove this dog is important to me. Edited August 31, 2022 by Brandcalfe Share this post Link to post Share on other sites
