abottleofsand
What to look out for in buying an old house
Hi, I am looking to buy a 25 year old corner terrace and would like to seek some advice on a few areas listed below
  1. areas to look out for for major red flags;
  2. Do I need to consider replacing the roofs and repainting the exterior?
  3. How often would we have to repaint the exterior of a house?
  4. How do I assess whether there are issues with pests? Terribly frightened of rats!
Also, in terms of reno, I am thinking of the 2 options below. May I know if a contractor is enough or I would require a builder, or an architect or any other experts I might have missed? Any high level indication of approx costs on the below options based on 3000sqft built up?
Option A -
simple reno necessities (wet works, electrical wiring, painting, carpentry, flooring) and also widening the existing windows to the floor-to-ceiling type.
Option B -
Option A + modifying the layout of one floor; expanding a staircase opening, breaking down some walls; partitioning part of the kitchen space to build a helpers room
Is option B considered a major reno or an A&A?
1. look for visible cracks or plaster/patching marks especially on the columns and beams.
2. if have the budget, might as well do it now especially if there's nothing done to the roof since the house was built. just paint the house to give it a fresh coat of paint. move into a "new" house must look new. :P
3. exterior painting is subjective. some houses I see have never been painted in ages so you see peeling paint, etc. the paint is there to provide a layer of water proofing to the house as plaster/bricks/concrete is porous. but exterior painting is a big cost for landed house since need to erect scaffoldings. I would say about 10 years once or when see peeling paint happening whichever comes first
4. can't escape pests. they can come over from your neighbour's house unless your house is surrounded by a moat. just try to keep your house clean so they won't stay and have parties.
contractor/builder are same actually.
for option A, a contractor/builder can do everything under his contract. some works could be subcontracted out by him eg: electrical, carpentry and fabrication of windows. your floor to ceiling window most likely need a PE to be involved due to safety issues.
for option B, you need to engage a PE as you are touching the stairs which is a structural element. unless you meant hacking down the walls next to the stairs then may not need if it's just brick walls and not columns or RC wall
both options are considered A&A just that B is a major A&A since there's more work to be done
  • Thanks 1
Thanks Snoozee,
May I know what are the risks if we don’t do up the roof now, is it only a matter of time when it’s required to be done?
also, would we have to check water tanks etc? Totally noob about this.
finally on both options a and b; would I need an architect?
1 minute ago, abottleofsand said:
Thanks Snoozee,
It’s the inconvenience of doing renovations when you are staying in the house If you need to redo the roof later. Over time, the roof tiles may have cracked and/or shifted which will result in leaks.
Usually landed houses don’t have water tanks unless the house is located on a very high ground as the water pressure may not be enough. So in this case a water tank and/or booster pump is needed
a&a works don’t need an architect
25 years isn't that old.
The roof can last much longer, just check it. Your builder will be able to check for you.
A&A without adding floors / changing the stairs should cost under 300k but costs may have gone up due to the Covid manpower issues.
Yes as a minimum do paint inside and out. You can also paint or add a waterproofing paint to the roof. It's worth it especially if you don't need to change it.
Work with your builder, they will have a proper checklist for you.
From my point of view, buying an old house must be very dangerous. Who knows from what materials this house was build and what technologies the builders used in that time. I think that is always better to opt for something new. For me, a new house means that I am safe. A two months ago, I bought a big house in Philipines. I am very pleased with my new acquisition. The house is made of high-quality materials and the price was very accessible. The most important thing for me is that my kids are happy.
From my own experience, I would not encourage you to get an old house. Yeah, I agree that all these old houses have astonishing character traits and historical features. Still, there's a bit of research needed to be done before considering getting an old house. First of all, an older home will come with older technology, and I'm sure you don't want this. Secondly, the remodeling is very costly. Very, trust me, I've been there. If you live in Australia, as I do, I would suggest considering some house and land packages sydney. It's super convenient since the building process is much faster and less stressful than a regular home restoration. You'll also see that there are so many savings with government grants available for house and land packages. Surely, the decision is up to you, but I thought it would be nice to share my thoughts with you!
Buying an old house was a terrible decision! I hated it!
If the floor of the house is uneven and you can see and feel it, then there`s definitely a problem with the foundation. Be sure to examine the foundation for splits by tapping the concrete. Water stains on the exterior walls of the house are also signs of drainage problems.
If the floor of the house is uneven and you can see and feel it, then there`s definitely a problem with the foundation. Be sure to examine the foundation for splits by tapping the concrete. Water stains on the exterior walls of the house are also signs of drainage problems. Examining the attic can also reveal important problems, especially with daylight coming in through cracks. The cost of roof repair or replacement depends on many factors, the exact answer can be given by experts after an inspection of the property. As for the experts - I applied to house plans and I liked them. Unfortunately, can't recommend others yet.
