icebaby
Aircon Quotes (From Aron)
Hi:
Need Help from all of you .
Will like to get a quote for a Mitsubishi Electric Starmax System 4 for replacement of my current aircon system
MXY-284AVA with MXY-GE10VA X3 and MXY-GE24VA.
If possible. wish to have quotation for MIT system and Dakin system as well for comparison.
Current budget is around 3.9K
Will prefer to have the followings conditions:
1) G23 Copper piping
2) Armaflex 1/2" insulator
3) 16mm drainage pipe
4) 3 years of workmanship
Thanks (Yeo_s_y@yahoo.com.sg)
Hi Yeo,
I have dropped you an email.
Thank you,
Aron (aronputt@gmail.com)
hi Aron, can quote me for system 3 Mitsubishi starmex 2x9000btu and 1x24000btu with all upgrde to 3/4inch?
thanks
Hi all renotalk members, we are running a special air-con promotion for MITSUBISHI STARMEX:- (Please email aron at aronputt@gmail.com for this promotion)
A) Special Renotalk Price: $3850 nett for Mitsubishi Inverter system 4 (new model, 18kbtu + 9kbtu X 3)
B) Special Renotalk Price: $2950 nett for Mitsubishi Inverter system 3 (new model, 9kbtu X 3)
B) Special Renotalk Price: $2899 nett for Panasonic Inverter system 3 (new model, 9kbtu X 3)
C) Special Renotalk Price for brands like daikin, toshiba, LG etc. Single Split, System 2/3/4 available for both inverter and non-inverter.
* Free & no obligation Site Survey
* Free 2 trips installation (1st trip to run piping, 2nd trip to put up air-cons [if needed])
* Free dismantle and disposal of old air-con
* Free upgrade to Armaflex class “O” 1/2 inch thick insulation,G23 copper pipe,keystone cable (made in singapore),16mm drainage pipe
* Special coordinating work between us and customer’s contractor
* Special appointed installation team
* Special supervising work by head of installer
Terms & Conditions
*All promotion items while stock last
*All prices include HDB standard installation
Thank you,
Aron
Terms & Conditions
Thank you,
Aron
Hi Aron, I've drop you an email. :)
I have replied to your email.
Thank you,
thanks
I have just PMed to you.
Thank you,
Hi Aron,
Could you pm me the best price for Mitsubishi Inverter system 4? (3 bedrooms; 1 living room (18k)). I intend to replace my current aircon system 2 (LG).
Staying in Sengkang. Thanks.
Thank you,
Hi Aron,
I try to call you and Ah Boon but no answer.
Want to check with you whether it is ok to hide the air-con ducting in the false ceiling?
Is there any ways to minimise the sweating? for example, by having thicker insulation?
Do you provide 1/2 inch Class 1 Armaflex instead of Class 0?
For the Mitsubishi Inverter system 4, do you have a larger BTU for the unit to be used in living room?
Hi Aron,
I have just PMed back to you.
Thank you,
Hi Aron,
Can quote me for Mitsubishi starmex system 3 with G22 pipe thanks
I have PMed back to you.
Thank you,
Terms & Conditions
Thank you,
Aron
Sent an email to you.
Hi Aron,
Can you please PM me your contact details and quote for the following?
I am looking for new aircon for my resale flat. 3 bedrooms + Living/Hall.
Old aircon is in 3 bedrooms only.
Regards
Edited by aluka
