icebaby
Aircon Quotes (From Aron)
Hi Aron, is this suitable for BTO 4 br 950 sqft?
A) Special Renotalk Price: $3850 nett for Mitsubishi Inverter system 4 (current model, 18kbtu + 9kbtu X 3)
Yes.
Thank you,
aron
(aronputt@gmail.com)
Can you quote for Daikin System 2 aircon (9k x 2) and (9k + 12k).
  1. How many years warranty on condenser?
  2. How many years warranty on fancoil?
  3. What type of copper pipe will you be using?
  4. What type of insulation will you be using?
  5. What type of drainage pipe will you be using?
  6. Will you be installing the bracket and powerpoint? If not, how much will it cost?
Hi hi
can i get the following quotes:
- Mitsubishi inverter system 4: 24kbtu + 9kbtu X 3 (preferably models: , MSY-GE24VA, MSY-GE10VA x 3 / MXY-4A28VA )
- Mitsubishi inverter system 2: 12kbtu + 9kbtu (pls recommend)
Pls quote with Armaflex class “O” 1/2 inch thick insulation,G22 copper pipe,keystone cable,16mm drainage pipe and 2 trips installation.
Also pls advise me the model numbers + compressor model recommended, and also what the warranty covers
Hello Aron,
Could you quote for: Mitsubishi Inverter system 4 (new model, 18kbtu + 9kbtu X 3)
Kindly quote with inclusion of Amaflex class "O" 1/2 inch thick insulation, G22 copper pipe,keystone cable, 16mm drainage pipe and 2 trips installation
Also kindly state the warranty covers too.
Really appreciate your reply at soonest for my unit under reno.
Thank you!
David
I have just PMed to you.
Thank you,
Aron (aronputt@gmail.com)
https://www.facebook...355281117982556
Hi hi
Thank you,
Hello Aron,
Thank you!
David
Hi David,
Thank you,
Can you quote me the price for Mitsubishi heavy ind. model MCM 100? Pls email me at bktan02@yahoo.com.sg.
I need 3 aircons in my three bedrooms and 2 aircons in my living room. I was told to get this model comes with 5 units with one compressor.
