icebaby
Aircon Quotes (From Aron)
On 3/29/2016 at 9:08 AM, dareme said:
Can I get a quote for the following:
  • Mitshubishi Starmex 5 ticks MXY4A28VA
  • 3 units of MSXYFJ10VE
  • 1 unit of MSXYFJ24VE
  • 1/2" insulation
  • 22 SWG copper piping
This is for installation in 4-rm BTO. Do let me know if you think if you have better specifications for my BTO. Thanks!
I have just PMed to you.
Thank you,
Aron (aronputt@gmail.com)
https://www.facebook.com/Star-Cool-Air-Condition-Engineering-Aron-Ah-Boon-355281117982556/?ref=hl
Hi all renotalk members, we are running a special air-con promotion for MITSUBISHI STARMEX:- (Please email aron at aronputt@gmail.com for this promotion)
A) Special Renotalk Price: $3850 nett for Mitsubishi Inverter system 4 (current model, 18kbtu + 9kbtu X 3)
B) Special Renotalk Price: $2999 nett for Mitsubishi Inverter system 3 (current model, 9kbtu X 3)
B) Special Renotalk Price: $2899 nett for Panasonic Inverter system 3 (new model, 9kbtu X 3)
C) Special Renotalk Price for brands like daikin, toshiba, LG etc. Single Split, System 2/3/4 available for both inverter and non-inverter.
* Free & no obligation Site Survey
* Free 2 trips installation (1st trip to run piping, 2nd trip to put up air-cons [if needed])
* Free dismantle and disposal of old air-con
* Free upgrade to Armaflex class “O” 1/2 inch thick insulation,G22 copper pipe,keystone cable (made in singapore),16mm drainage pipe
* Special coordinating work between us and customer’s contractor
* Special appointed installation team
* Special supervising work by head of installer
Terms & Conditions
*All promotion items while stock last
*All prices include HDB standard installation
We have set up a facebook page (link below) specially for you and all Star Cool customer who will like to seek for after sales service, air-con advise and quotation. Please kindly dropby and give us a like if you are satisfy with our services.
This facebook page will also serve as a channel for you to contact us if you have any enquiry in regards to your aircon.
Thank you,
Aron
Hi Aron,
I am looking to install a 5 ticks ME Starmex or Panasonic System 4 for my 5 room BTO.
Can you pm me your recommended models and quotations?
Samuel
On 4/5/2016 at 3:26 PM, samuelgoh said:
Hi Aron,
Samuel
 Hi Samuel,
Thank you,
Hi Aron,
I am going to replace my old aircons in HDB, can you please quote me the price of 5ticks Mitsubishi wall mount system 3(9000x2, 12000x1)?
Thanks,
On 4/7/2016 at 4:42 PM, jqjkww said:
Hi Aron,
Thanks,
Thank you,
Hi Aron,
Please quote for Daikin System 2 (3MKS50FSG x 1 + FTKS25DVM x 2) with 2 times installation, 1/2 inch Armaflex CLASS 1 insulation, G23 100% copper piping, 16mm drain pipe for new installation.
Kindly advise the material for the brackets, drain pipe, trunking and power wire used.
Do you provide any servicing?
Hi Aron,
Kindly quote for ME Inverter System 3 for HDB:
- Compressor is MXY-3A28VA
- Cooling Capacity:
  • 2 x 9K BTU + 1 x 12K BTU
- Kindly include GST, standard installation specification, material upgrade option, warranty etc...
- Also require to remove old air-con compressor/ fan coil x 3/ copper piping/ water piping.
Thank You!
On 4/11/2016 at 1:28 PM, BabyPooh said:
Hi Aron,
Thank you,
On 4/11/2016 at 0:24 AM, warrior79 said:
Hi Aron,
- Cooling Capacity:
Thank You!
Thank you,
