phoenix77
Kitchen Reno
Hi
Am new to this site. Would like to reno my aged kitchen. Was considering IKEA but after some researching, found it to be not too adviseable as the material is made of chipboard. Any contractors to recommend? Good and reliable.. HELP plssssss
Me new too.
I'm looking to redo some portions of my kitchen. Mainly my kitchen cabinets, and minor re-tiling for the damaged portions.
For your reference this 'Bao Ga Liao' Kitchen Makeover Deal @ $12,880
Demolition Work
01. Hack off existing floor tiles
02. Hack off existing wall tiles
03. Dismantle existing kitchen cabinet
04. Dismantle existing water pipe
05. Dismantle existing wiring / casing
Wet Works
06. Provide building materials
07. Provide designer wall tiles ($2.80 psf) max. 400sqft
08. Provide designer anti-slip homogeneous floor tiles ($3.20 psf)
09. Apply waterproofing membrance using 104 Quickseal (recommended by HDB)
10. Provide labour to construct kitchen cabinet base
11. Provide labour to construct fridge base
12. Provide labour to construct washing machine base
13. Provide labour to lay kitchen wall tiles
14. Provide labour to lay ktichen floor tiles
Plumbing Works
15. Provide labour and materials to install new stainless steel water pipe (cold)
16. Provide labour and materials install new inlet / outlet pipe (PVC)
17. Provide labour to install 1 set of kitchen sink and tap
18. Supply 1 set of stainless steel double bowl kitchen sink
19. Supply 1 set of kitchen sink tap
Electrical Works
20. Provide labour and materials to install new casing for kitchen
21. Provide labour and materials to install 2 nos of lighting points
22. Supply 2 sets of ceiling lights
23. Provide labour to install 2 sets of ceiling lights
Carpentry Works
24. Design, fabricate and install 20 feet ktichen cabinet with ABS trimming in laminate finish
25. Fabricate and install 10 feet kitchen top using solid surface
26. Provide labour and materials to install 1 set of built in dishrack
27. Provide labour and materials to install 1 panel of stainless steel backing at hob area
28. Supply 1 set of branded stainless hood
29. Supply 1 set of branded glass hob
30. Supply 1 set of cutlery tray
Miscellaneous
31. Provide cardboard protection during renovation
32. Chemical / Acid wash after renovation
Edited by blackwhite.sg
