samuel333
Air Con Woes
I am still contemplating over inverter or non-inverter.
My air con guys told me if I am going for system 2, actually no need inverter.
Probably savings is quite negligible.
I am most likely gonna on for like 8-10hr daily for one unit.
The other unit most likely be in used only 2-3 years later at least after my child sleeps alone.
Anyone actually can substantiate their savings over their electricity bill on the before and after inverter air con installed.
Thanks :sport-smiley-004:
If u use non inverter, u have to get those with dual compressor. Like Panasonic.
Then it will suits u as u use one room most of the time.
But 2-3 years later, the amount of energy u use will be higher by 20-40% if u use 2 @ the same time, compared to inverter.
Electricity bill is getting higher every year, inverter in the long run can save on electricity bill. If you switch ON for 8-10 hours on weekday and almost 24 hours on weekend, best get the inverter model.
Do you know which area the non-inverter waste electricity?
