paperger85
3Rm Resale Flat
I recently bought a repossessed flat from HDB and the condition was abysmal. It had tiles on the walls of the living room which I need to hack off.
I don't need anything fancy, just simple reno and I am surprised that I was quoted so high. Please let me know if you think the price I am quoted is the norm. My toilet and bathroom is joined so I have no idea why he quoted separately and so high some more.
Living
supply & install low shoe cabinet below window w/sliding dr & cushion top (approx 5.5ft L) $750.00
supply & install sliding glass window (approx 23sf) $380.00
supply & install aluminum window grilles (approx 23sf) $190.00
Kitchen
check & repair window (depends on viability) FOC
supply & install wood laminated box to conceal existing piping w/door (approx 1.5ft W x 6ft Ht) $280.00
supply & erect hollow block sink & stove w/tiles top & exterior $1,300.00
supply & install PVC sliding door w/aluminum frame below sink & stove $360.00
installation of sink tap FOC
supply & install outflow pipe at sink $50.00
supply & install wall mounted folding table w/heavy duty bar (approx 3ft L x 18" D) $200.00
supply & construct cabinet base w/tiles skirting $350.00
supply & install bottom cabinet w/swing door (approx 5ft) $600.00
supply & install solid surface top at cabinet (approx 5ft) $400.00
supply & construct washer base w/tiles top & skirting $180.00
supply & construct fridge base w/tiles top & skirting $180.00
relocate washer point w/extension piping $180.00
cut off existing kitchen entrance door top arc + make smooth $80.00
Master Room
supply & install sliding door wardrobe in laminated wood (approx 6.2ft x 31" D x full ht) $1,680.00
supply & seal up door top panel w/gypsum board (2 sided) $120.00
supply & install conceal type slide out mirror (optional) $180.00
Bedroom 2
Toilet/Bathroom
installation of new WC $120.00
installation of toilet & bathroom accessories FOC
installation of washing basin $60.00
installation of basin tap FOC
supply & install outflow pipe at wash basin $50.00
supply & install heater point $120.00
installation of instant heater $60.00
supply & install water filter at toilet & bathroom flooring FOC
Wet Works
supply & overlay homogeneous floor tiles at toilet (up to $3/sf)approx 20sf + $2,400.00
supply & overlay homogeneous wall tiles at toilet (up to $3/sf) approx 140sf
supply & overlay homogeneous floor tiles at bathroom(up to $3/sf) approx 20sf + $2,400.00
supply & lay homogeneous wall tiles at bathroom(up to $3/sf) approx 140sf
supply & lay water proofing membrane at toilet $100.00
supply & lay water proofing membrane at bathroom $100.00
Hacking/demolition Works
hack existing wall tiles living room (approx 380sf) $950.00
hack existing wall tiles at kitchen (approx 330sf) $800.00
hack existing hollow block sink & stove $300.00
Electrical works
to be confirmed again on types and quantity TBC
Painting Works
supply & apply sealer at ceiling & wall $300.00
supply & emulsion paint whole house(ICI pentalite or nippon vinilex) max 5 colors $1,000.00
supply & paint existing water piping (toilet & bathroom) FOC
supply & paint existing bedroom room doors frame FOC
supply & paint main door frame FOC
supply & paint utility room door frame 1 FOC
Misc
polish existing marble floor tiles **** & 2 bedrooms (approx 423sf) $930.00
supply & install stainless steel piping at kitchen, toilet & bathroom $850.00
supply & plaster whole house including kitchen & utility room $2,300.00
supply & lay corrugated paper roll during work process to protect tiling FOC
acid wash whole house FOC
uploading of raw materials FOC
clearance & disposal of debris $180.00
supply of sand (for plastering & make smooth wall) $700.00
make smooth living & kitchen wall after hacking w/cement & chemical + leveling up upp portion of $1,180.00
kitchen wall with lower portion
application of HDB hacking permit $200.00
Total $22,970
Edited by paperger85
