Weijie123
How to test the lights from taobao
Hi guys,
We just bought a living room light from taobao to test its quality. We would like to check how we connect up the lights to test its brightness etc? As our electrician will only come in when we bought all the lights.
Thank you.
Get a piece of cable with a 3 core wire. 1 end of the cable should be connected to a 3 pin plug. The other end of cable will have the LNE wire expose, cut off the insulation of the 3 wires (about 5mm) to expose the copper wire. Connect the L,N & E copper wire to the correct terminal of the light. Make sure the wires are not touching anything besides the connectors. If there is no E connection, tape it with insulation tape. Plug the 3 pin plug to the wall socket. Turn on and you have light... hopefully.
If you have problem understanding the above, you should not even attempt yourself. Get a friend with electrical knowledge to help.
