fang fang 0 Report post Posted April 14, 2007 Greetings to all!Does anyone know about parquet floorings? Whats the pros and cons? Or is there any flooring that you think is worth recommending? Please feel free to response. warm regards Share this post Link to post Share on other sites
newbiee 0 Report post Posted April 14, 2007 Greetings to all!Does anyone know about parquet floorings? Whats the pros and cons? Or is there any flooring that you think is worth recommending? Please feel free to response. !! warm regardsProNice to lie onConsColor limitationeasily scratch Share this post Link to post Share on other sites
TYM 0 Report post Posted April 15, 2007 ProBrings Warmth and natural beauty to a homeConsAlways keep dry to prevent warping, splitting and crackingHigh maintenacne. Daily cleaning recommended.Surface can be renewed with the use of sanding machine that strips away the top layer, exposing a new layer that can be repolished and resealed.Some tips I read about wood flooring:1. Sweep or vacuum as often as necessary to remove any loose dirt or grit before it scratches the floor.2. When moving heavy object like furniture, slip a blanket or a carpet under each foot of the object to prevent scratching and gouging.3. Use floor protectors on the leg of your furniture to prevent scratching and gouging.4. When buying new furniture, pay special attention to casters or wheels.5. In areas with busy traffic, like doorways or corridors, make use of runners and area rugs. For floors that are beginning to show wear and tear, recoat before the damage is too heavy.6. As the wood in your floor ages, it will change colour. Certain species of wood, such as cherry, change colour more drastically than others. You should periodically move carpets and furniture to allow the floor to age uniformly. Share this post Link to post Share on other sites
