sleepsherpa
Flip Mattress Topper from Coop
Coop is best known for its line of adjustable loft pillows. I was recently given a free sample of their new mattress topper for review. This topper can be flipped for a soft or firm feel making it more versatile than your typical topper. A queen size retails for $269.95 so it is certainly more expensive than most but since you get two feels in one topper there’s a lot of value there too.
Overview of the Flip Mattress Topper
You can get the best price on your Coop topper through their website. Most mattress toppers do not come with a trial period but Coop gives you 100 nights to try it out to see if it is a good solution for your needs. If you don’t like it you can contact Coop and they will give you a prepaid return label so it is also free return shipping. You also get a 5 year warranty but that only covers you against a manufacturer defect under normal use. Since it’s a topper, there’s really not much that can go wrong with it, and if there is, you will usually know it right away and can just return or exchange it.
The topper comes packaged in a small container.
coop flip topper
Here’s a video overview of the Coop Flip Mattress topper.
How Much Does the Coop Mattress Topper Cost?
Below are the most recent prices from the Coop website.  Currently, they only offer the topper in a queen and king size.
Size Retail Price
Queen $269.95
King $289.95
Construction of the Copp Flip Mattress Topper
Below are the construction details of the topper. The darker foam is the soft foam and the light foam is the firmer foam.
coop firmness
  • Includes our top-rated Mattress Protector for 100% waterproof protection
  • Elastic bands on each corner ensure a secure fit to your mattress
  • 5-year limited warranty
  • 100-night sleep trial
Dimensions
Queen: 57″ (W) x 78″ (L) x 4″ (H)
King: 74″ (W) x 78″ (L) x 4″ (H)
Materials
Mattress Topper: CertiPUR-US certified polyurethane foam
Cover: polyester
Mattress Protector: bamboo-derived viscose rayon and polyester, with waterproof backing
My Coop Mattress Topper Findings
Although this topper is pricey, there are some added features that make it worth the expense. First, you get their waterproof cover included. This is a machine washable cover with elastic bands that will keep the topper in place and keep it clean.
coop band
The topper is 4 inches thick which means it’s going to substantially change the feel of your current mattress. The soft side will really cradle your body and provide substantial pressure relief for even the firmest of mattresses.
The firm side is still going to provide quite a bit of pressure relief but with less sinking. Most toppers are only 2-3 inches thick and so having a 4 inch topper is truly getting 2 toppers in one.
The elastic bands are designed to be flexible enough to work with thick mattresses. In the picture above it is attached to a 14-inch thick mattress.
Here’s a picture illustrating sinkage with my 14 lb. bowling ball on the topper. This is the soft side of the topper on top.
coop-topper-sinkage.jpeg?strip=all&lossy
I highly recommend this topper for guest beds that are structurally sound, meaning they still support sleepers well but are a bit too firm. Having the ability to adjust firmnesses ensures your guests will get the optimal firmness without having to buy and store two separate toppers.
