noodlemelon
Help! Seeking advice on renovation issues
Hi, I’m renovating a resale HDB and met a few issues. Would like to check if I can seek some advice or solutions here.
1. The ex owner had the aircon water pipe pass through the corner of the frame of the sewage box up in the toilet. As I will install new aircon, the old pipe was removed and now there is a hole in the frame. My aircon vendor will run the pipe in a different route so the hole will be there. My ID said it was cut by previous aircon ppl and he is not replacing. Wonder if anyone has encountered this. How did you patch up the hole?
2. My ID proposed to lay new concealed copper water pipes. However, on the day of installation after they dismantled the old pipes, they informed me that there is not enough space or "手路“ for the part in the yard and it has to be exposed. As there is no other option, i accepted. However, the result seems quite ugly. I wonder if it can be routed as illustrated in red.
Any advice is most welcome and appreciated! Thanks!
Edited by noodlemelon
