Daikin air conditioners are known for their reliability and long-lasting performance. However, like any other electronic device, they can also encounter problems, and one of the most common issues is the blinking light on the unit. The blinking light on your Daikin air conditioner indicates an error or fault in the system, and it’s essential to understand the reasons behind it and how to solve the issue. In this article, we will discuss the common reasons why your Daikin air conditioner light is blinking and how to fix it.
Reasons for Daikin Aircon Light Blinking
  1. Dirty Air Filters
One of the most common reasons for a blinking light on a Daikin air conditioner is dirty air filters. When the air filters are dirty or clogged, the air conditioner’s performance is reduced, causing the system to work harder to cool the room. This increased workload can lead to overheating, which triggers the blinking light. To solve this issue, you need to clean or replace the air filters. Cleaning the air filters is an easy task that you can do yourself. However, if you are not comfortable doing it, you can seek the help of a professional.
  1. Low Refrigerant
Another reason why your Daikin air conditioner light is blinking could be due to low refrigerant levels. When the refrigerant levels are low, the air conditioner’s performance is reduced, and the system has to work harder to cool the room. This increased workload can cause the system to overheat, triggering the blinking light. To solve this issue, you need to contact a professional technician to recharge the refrigerant levels in the system.
  1. Electrical Issues
Electrical issues can also cause the Daikin air conditioner light to blink. Electrical problems can include faulty wiring, a blown fuse, or a tripped circuit breaker. If you suspect that the blinking light is due to an electrical issue, you should turn off the air conditioner immediately and contact a professional technician to fix the issue. Electrical problems can be dangerous and should only be handled by a professional.
  1. Malfunctioning Compressor
The compressor, which circulates refrigerant and cools the air, is the central component of the air conditioning system. When the compressor malfunctions, the air conditioner’s performance is reduced, causing the system to work harder to cool the room. This increased workload can cause the system to overheat, triggering the blinking light. To solve this issue, you need to contact a professional technician to replace the malfunctioning compressor.
  1. Sensor Issues
The Daikin air conditioner has sensors that detect the room’s temperature and adjust the cooling accordingly. When the sensors malfunction, they can send the wrong signals to the air conditioning system, causing the system to work harder than necessary. This increased workload can cause the system to overheat, triggering the blinking light. To solve this issue, you need to contact a professional technician to fix the sensor issue.
How to solve the daikin aircon light blinking issue
If your Daikin air conditioner light is blinking, it is an indication that there is a problem with the system. The blinking light can be caused by several factors, including dirty air filters, low refrigerant levels, electrical issues, malfunctioning compressors, and sensor issues. In this section, we will discuss how to solve the Daikin aircon light blinking issue.
  1. Clean or Replace the Air Filters
Dirty air filters are one of the most common reasons why the Daikin aircon light is blinking. To solve this issue, you need to clean or replace the air filters. Cleaning the air filters is an easy task that you can do yourself. Some steps for following
Step 1: Turn off the air conditioner and unplug it from the power source.
Step 2: Locate the air filters. They are usually located behind the front cover of the air conditioning unit.
Step 3: Remove the air filters from the unit.
Step 4: Clean the air filters with a soft brush or vacuum cleaner. If the air filters are too dirty or damaged, replace them with new ones.
Step 5: Put the air filters back into the unit and turn on the air conditioner.
  1. Check the Refrigerant Levels
Low refrigerant levels can also cause the Daikin aircon light to blink. To solve this issue, you need to check the refrigerant levels in the system. This task requires the expertise of a professional technician. Here are the steps that a professional technician will follow:
Step 2: Remove the cover of the air conditioning unit to access the refrigerant lines.
Step 3: Connect a pressure gauge to the refrigerant lines to check the refrigerant levels.
Step 4: If the refrigerant levels are low, the technician will add refrigerant to the system.
Step 5: After adding refrigerant, the technician will test the system to ensure it is working correctly.
  1. Check for Electrical Issues
Electrical issues can also cause the Daikin aircon light to blink. To solve this issue, you need to check for any faulty wiring, blown fuse, or tripped circuit breaker. If you suspect that the blinking light is due to an electrical issue, you should turn off the air conditioner immediately and contact a professional technician to fix the issue. Here are the steps that a professional technician will follow:
Step 2: Inspect the electrical components of the air conditioning system, including the wiring, fuse, and circuit breaker.
Step 3: If the technician identifies any faulty wiring, blown fuse, or tripped circuit breaker, they will replace or repair the component.
Step 4: After fixing the electrical issue, the technician will test the system to ensure it is working correctly.
  1. Check for Malfunctioning Compressor
The compressor is responsible for circulating the refrigerant and cooling the air in the air conditioning system. If the compressor is malfunctioning, it can cause the Daikin aircon light to blink. To solve this issue, you need to contact a professional technician to replace the malfunctioning compressor. Here are the steps that a professional technician will follow:
Step 2: Remove the cover of the air conditioning unit to access the compressor.
Step 3: The technician will inspect the compressor to identify the problem.
Step 4: If the compressor is malfunctioning, the technician will replace it with a new one.
Step 5: After replacing the compressor, the technician will test the system to ensure it is working correctly.
