donut88
Losing Hair
hi,
if i'm been using a too strong shampoo, which i never used before, and realised that i'm losing hair.
when i switch to my regular 'lighter' shampoo, will my hair grow back or gets better?
I'm getting worried........ :unsure:
Unlikely it will grow back. The root of your hair has probably closed up due to the strong chemicals in your previous shampoo.
Once hair drop, can't wind back the clock liao. Unless you see hair specialist.
But by switching back to your safe shampoo, the speed of losing hair may slow down or even stop.
If you have to see a specialist for your hair, go to a licensed doctor and not those Yun whatever type of hair care. Trichologists themselves are not normally medically qualified although members of the medical profession can undertake courses and/or careers within trichology.
The hair cleansing routine largely depends on the hair-type. People having oily hair may need to wash their hair regularly, while people having dry hair can wash it twice a week. Never use too hot or too cold water to wash the hair. While cleaning or massaging the hair, one should always use the fingertips and not the nails to gently clean your scalp.One should use a wide-tooth comb to untangle the hair and comb in downward direction. Using a wooden or tortoise shell comb is a better idea than using a rubber comb. Avoid combing wet hair, as wet hair can easily break.
If possible, allow the hair to dry naturally. Avoid using blow dryer as its heat can damage the hair, and also make it look coarse and lifeless.
Protect the hair from sudden environmental changes, while going out to a beach or a pool. One must use an effective conditioner as it protects the hair from the sun, chlorine, and sea water. One should also wear a protective hat or a cap to avoid overexposing the hair to the sun, salt or chlorinated water and pollution.
francis
Link Building
I have the same problem too. But ever since I use the shampoo from Nuskin, it helps a lot. My hair is much better now. Besides, the Galvanic Spa has been reported to help in hair loss. Not just hair loss, it also helps with skin & body. Do PM me @ ladym1976@gmail.com if you are interested to learn more about the products.
Anybody tried Yunnan or Beijing101? On and off they do sponsor and ads in TV through mediacorp artiste but heard last tome a lot of people complained.
Thoght of trying but don't want to end up.....
Hey! I had a problem with hair loss for a long time. I tried many different shampoos, but none of them worked for me. A friend of mine advised me one hair spray after I wash it. Here I will leave the link https://www.pai-shau.com/products/texture-dust . In general, use any shampoo for hair that is of less quality and after you dry your head, apply the liquid from this spray. Your hair will become beautiful, voluminous, and will stop falling out.
