pk_shl
R Lights With Ceiling Fans Bright Enough For Bedroom?
i wan to buy ceiling fans with lights for my 3bedrooms. wonder if those light that comes with ceiling fan are they bright enough for a bedroom at night?
you can choose the lights
if you want you can choose 4 x 32w which will give you 128w
should be bright enough liao?
me using a single 32w, more than enough for me
but then again, i only go to my bedroom when i sleep :P
normally fan that comes with light, the fan wind not strong, is it true?
Not true!
My dining area fan has 4 lights and since it has a 9 feet+ ceiling height
I put a ceiling fan ... I think 54" and I find it very cool.
the lights are 11 watts each- the philips twister ones.
I think how cool the wind is depends on ceiling height n motor... imho
Lights are generally classify into the following:
Ambient lighting
Provides general illumination indoors for daily activities, and outdoors for safety and security.
Task lighting
Facilitates particular tasks that require more light than is needed for general illumination, such as under-counter kitchen lights, table lamps, or bathroom mirror lights.
Accent lighting
Draws attention to special features or enhances the aesthetic qualities of an indoor or outdoor environment.
Of course the light on the fan is bright enough to provide general illumination for the room. But if you are going to depend on the one light for all your usage, then definitely not enough.
Not true!
Thanks. :) settle one doubts.
want to rake this thread up again...any idea if the light kits can work only on certain fans or on all fans? i would like to get the kdk baby fan for my bedrooms but not sure if the light kits works with it... anybody has recommendation on fans with lights which arent so expensive?
Edited by melvin
