xarain
"special Glass" ?
Hi Xicloudix,
Please PM me the contact as well... Thanks a lot in advance, appreciate the infor.
Byron
Do share the outcome guys! :)
thanks much
thanks much
sorry for replying so late
heres the webpage
http://www.legardien.com/
but i think best to call up, coz their webpage does not have everything they have, I have one of their catalogue, which has the glass you wanted but forgot what it calls, will try to find the catalogue and update if found(got picture see more realistic, no pic dun know say the correct thing or not), ...
heres the webpage
Hi legardien sells special glass lei... not these smartflim we are saying... the smart film is a foil usually stick over glass but can be opaque or totally transparent when a small electric voltage is pass thru it...
Very expensive cost about $12,000 for sometin like 50sq feet...
I check with Legardien... they don't sell something like this... they are into special glass for usually commercial or artchitectual purpose ... like Eglass etc
Thank anyway for the recommendation...
since it turns clear when you touch
means whenever it is clear it'll consume 3.5W (per hour or per minute?)
if it's a full height full wall thing, it's likely to be around 10sqm?
should be something like that bah :dunno:
Our household electricity is calculated in kWh units (currently is 23.88cents).. meaning if you use 1000W for 1 hour then the bill is 23.88cents.
For 3.5W, it costs 23.88cents when you can use it for ~285hrs. :good:
Therefore its not really that expensive to use the Electronchromic glass just that the item itself is quite expensive :yamseng:
